weight 4 inch concrete can hold
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jan 2010
    FL,USA
    673
    54
    49
    Default weight 4 inch concrete can hold
    What is the most heavy machine you think I can put on 4" of concrete? I tried looking up what lbs per foot concrete can hold but only got back how much concrete weighs.
    Please let me know thinking about putting a 7500 lbs machine on 4" of concrete
    Apr 2008
    Troy, NY
    495
    76
    The answer depends on a few things which you will need to provide:
    - The strength of the concrete mix
    - The concentration of the weight at support points (i.e. 2500 lbs each on three feet or 1250 lbs each on 6 feet)
    - The distance between each support point
    - Any reinforcement in the slab?
    Henry
    Feb 2009
    Tucson, AZ
    630
    12
    23
    Hard to say exactly without knowing the specs of your particular floor, but, I think the average slab pour is done to ~ 3,000-3,500 psi. So I should venture a guess that a 7,500# machine should not have any issues. I'm sure others more knowledgeable than I will chime in...
    Jun 2010
    Ellwood City, PA
    127
    I don't know what the psi per sq ft is but I park my forklift on my shop floor and it is 4" deep. The lift weighs 9000lbs, Plus I don't know what it weighs but I have a 16" hd cincinnati shaper sitting on the same floor.
    Feb 2009
    Tucson, AZ
    630
    12
    23
    Quote Originally Posted by enterprise lathe View Post
    ... psi per sq ft ...
    Is that an oxymoron?
  6. Likes HammerPoundWeld liked this post
    Jul 2004
    Houston, TX USA
    27,440
    My 14,700 LB P&W 3B Jig Bore has been there for over 10 years, three pointed on 5 X 5 X 5/8" steel pads. The floor could care less, but for close work, I'll relevel.
    jigbore pictures by johnoder - Photobucket
    J.O.
    Jan 2010
    FL,USA
    673
    54
    49
    Seems like a lot of people are holding a lot more weight than I plan on putting on it with no problem.
  9. #8
    May 2010
    Cambridge, MA
    1,652
    68
    921
    What is under the concrete? If its granite then you can put the Great Pyramid of Giza on it. If you basement is floating on water then it will depend on the breadth of the machine in the longest dimension, and the distance from the wall. Usually if a foundation cracks its because there is bad subsurface. For example, let's say it is like this
    XXXXXX..................XXXXXXXXXXXXXXX
    Where "X" is rock and "." is sand. If you put a heavy object over the sand the concrete will crack depending on how heavy the object is and how far away it is from the nearest X. Engineers call it a "cantilever".
  10. Likes S_W_Bausch liked this post
  11. #9
    Feb 2007
    St. George, Utah
    530
    119
    252
    Quote Originally Posted by jscpm View Post
    What is under the concrete? If its granite then you can put the Great Pyramid of Giza on it. If you basement is floating on water then it will depend on the breadth of the machine in the longest dimension.
    Yes, and even more important than what's under it, is what is not under it! If the substrate was not good to start with, was not properly compacted or has settled, a surprisingly light weight or impact will break the slab.
  12. Likes adama liked this post
  13. #10
    Jan 2005
    Roseville, CA
    3,861
    26
    16
    No one has yet mentioned it, but in several older threads there is discussion of how much the concrete floor will flex under heavy weights. In other words, if you are putting a lathe on the floor, someone walking by could actually move it, which could affect accuracy. Also, placing the ends of a lathe across two slabs separated by a joint is not a good idea, as they can move in relation to each other.
  14. #11
    Sep 2007
    Woodinville, WA
    1,704
    185
    345
    ...but again, that all depends on what's under it... I see flex all the time with concrete building floors (data centers have some very heayy loads), but not on good grade slabs.
    On a correctly compacted base of suitable material, it's not going to "flex". If it's garden soil, or uncompacted backfill, well....
  15. #12
    May 2007
    Vancouver Island
    257
    12
    Default cement support
    Come on guys:: Don't forget the types of concrete, the amount of rebar, and/or the amount of fibre, the amount of tamping, use of a vibrator, etc. There is not a simple answer. Also, hand pour or truck, amount of cement to sand, to gravel. It varies. Ask a professional cement outfit. Wayne.
  16. #13
    Sep 2005
    il.
    6,558
    29
    1175
    ding,ding,ding,ding,ding,ding,ding
  17. #14
    Jan 2007
    Norfolk, UK
    17,016
    12659
    12179
    + another for WHAT'S UNDERNEATH?
    If you don't know,......... I'd borrow / hire / scrounge a 4" core drill and cut a few holes for a looksee.
  18. #15
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    926
    Quote Originally Posted by Limy Sami View Post
    And if the lookee loo doesn't give any confidence, bring in a larger diameter drill and drill under each (planned) pressure point, and expect to excavate a few feet to install your better fill (and a thicker concrete pad).
    That new pad may still sink, but since it is not attached to the slab, the slab shouldn't crack.
    Years ago, someone proposed a series of small spindly piers, along the line of "stab in a digging bar and wiggle it around" as a way to allow a somewhat thin slab to avoid cracking (aid work in developing regions, perhaps).
    Frank Lloyd Wright's 'lily pads' worked, but that was on another scale.
    Soil Bearing Capacity Table
    Type of Soil Load Bearing
    (Pounds Per Square Foot)
    Rock w/ Gravel 6,000 psf +
    Gravel 5000 psf
    Sandy Gravel 5000 psf
    Sand 3000 psf
    Silt Sand 3000 psf
    Silt Gravel 3000 psf
    Gravel w/ Clay 3000 psf
    Clay 2000 psf
    Sandy Clay 2000 psf
    Silt Clay 2000 psf
  19. #16
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Quote Originally Posted by MBG View Post
    All depends on WHERE ..... "Location: FL,USA"
    How close to a sink hole are you??
    and just for your info, 4 inches is barely a driveway, for a little car....
    use a proper slab min 6 inches reinforced...8 is better.
  20. #17
    Aug 2006
    Hesperia, SoCal
    4,369
    987
    631
    Quote Originally Posted by Gary E View Post
    use a proper slab min 6 inches reinforced...8 is better..
    "....for our info" Gary? That's absurd, for all the reasons above and more. You must have missed John's 14,700 pound jig bore above!
    As for "use a proper slab min 6 inches reinforced...8 is better." with that "logic", why not 18" with 24" being better? Useful advise is being sought here.
    MBG, unless the slab is already showing signs of failure, I wouldn't hesitate to bring that machine in. Let's suppose that you are unlucky and the 4" slab doesn't easily hold it, what better test?
    Won't go to China.... push the machine out of the way and cut a hole in the floor, excavate, compact a 12" layer 3/4" CRB (crusher-run-base), pour a 6"* reinforced slab and let it cure for a month. But fer crimminy sakes, don't go to all that silliness unless the need is proven, which is highly unlikely!
    *6" because that will still be below the minimum ready mix delivery charge and you'll be adding useful anti-vibration mass. With that kind of prep, 4", 4,000 PSI, reinforced mud would be overkill for strength on that moderate load.
    Don't dink around with "expansion joint"* between the old and new, too many people don't understand that. The new slab WILL SHRINK! Guarenteed. It can never apply pressure to the hole in the long-ago-cured slab around it. You'll just make a hard to keep clean recess around your lathe. Do dowel them together, help the old slab to remain stable, that's "flush" to the new.
    *Do use expansion joint around an existing slab, before you pour around it.
    Oh yeah MBG, how do you get around all those "sink holes" on the way to.. wherever?
    Bob
  21. Likes S_W_Bausch liked this post
  22. #18
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1003
    +3 for what's under the slab.
    What I find is if you run an empty pallet jack across a poured floor you can probably find where it's solid and where it's hollow so to speak. There's a different sound that you can pickup with your ear.
  23. #19
    Jan 2007
    Norfolk, UK
    17,016
    12659
    12179
    If you don't know the mix etc, if you do core drill the slab the slug will tell you a lot.
  24. #20
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Here's one of your Floriduh SINK Holes....
