awake
Titanium
- Jan 24, 2006
- Angier, North Carolina
I'm looking at a Bridgeport Series II Special - the one with the Series II base and the 2J2 2HP variable speed head. It is not under power, so I can't see it run. The table ways are reasonably good, from what I can see. It has a DRO and X-axis powerfeed.
Three questions:
1) Given that I cannot inspect it under power, is there anything that I should and can check out? (Obviously I'll check the table ways, backlash, etc.; also, I can check the DRO and the power feed, as they are on a separate 110v circuit.) The seller is a friend of a friend, and I think there is reasonable grounds for trust ... but no way to know for sure ahead of time.
2) Based on the description above, and the fact that it is not under power, is $1500 a good price? I've been watching for something along these lines for quite some time, and it *seems* like a good price compared to what I've seen ... but I don't know if the Series II Special tends to run higher or lower than the more common (around here) Series I.
3) I've seen a weight of 5000 lbs for the regular Series II ... but I'm not getting a clear sense of how much weight, if any, is reduced by the Special version. Anybody know? And does anybody happen to know how much the base and knee would weigh with the turret removed? (Trying to think through options for moving it ...)
Many thanks!
Three questions:
Many thanks!
