What are brake rotors made of?
Results 1 to 20 of 20
    Jan 2011
    Fort Collins, Colorado
    350
    161
    37
    Default What are brake rotors made of?
    Or what should I make them out of would be a better question
    Feb 2006
    Indiana
    11,802
    414
    3033
    Cast iron, if you mean automobile or truck brakes. Bicycle rotors may be stainless steel or something.
    Larry
    Jan 2005
    Victoria, Texas, USA
    3,532
    1521
    747
    Being more specific, a nodular cast iron. At least I read that somewhere in my past.
    17,106
    7259
    5362
    Quote Originally Posted by 4GSR View Post
    Meehanite for some. Weird stuff for aircraft - from Berylium alloys (toxic dust!) to carbon fibre.
    But 'make' for what?
    Airheart and others offer brake disk, drum, internal shoes, external bands, et al (mechancial and hydraulic) mass-produced as parts in sizes and ratings from electric skateboards thru Go Karts to supercars. Warner and at least one Japanese firm do the same for electromagnetic actuated - similar to auto A/C compressor clutches.
    Under a hundred bucks quantity of one for a 6" or so Go Kart size that'll stop a fair sized lathe smartly with an average workholder and workpiece mass.
    HP rating of twice that of the motor is a good start. Work up from there.
    Bill
    Jul 2004
    Houston, TX USA
    27,210
    Nov 2007
    marysville ohio
    8,513
    2398
    5370
    Indy Cars and F1 use carbon rotors and pads
    Jan 2011
    350
    161
    37
    Thanks for the replies fellas!
    I could probably order one... but i thought if I had the right material laying around I might just make it.
    Its for a four wheeler, we are converting it to have tracks for snow
    thanks again
    Nick
    Jan 2007
    Norfolk, UK
    16,681
    12322
    11792
    35 + years ago I used to make a part not unlike a brake rotor (disc), 6off at a time - engine lathe & mill work.
    From castings there's a lot more work than you first think,......... from solid there's even more - not to mention swarf.
  9. Likes jdj liked this post
  10. #9
    17,106
    7259
    5362
    Quote Originally Posted by Avsfan135 View Post
    thanks again
    Nick
    Then use whatever fits the donor drive-axle's mount-up?
    Not that brakes are going to have quite the same task OR effect for a tracked vehicle, but Skiddo conveyor-belt track style... or proper 'Snow Weasel' independent steerables, or ...???
    Wheel long ago invented in any case, no shame in adopting whatever is known to work well.
    Bill
  11. Likes Limy Sami liked this post
  12. #10
    Dec 2009
    Long Beach CA
    493
    11
    187
    conventional automotive brake rotors are cast from G3000 grey cast iron. These work well with a pad material designed to operate using adherent friction. Most of the European system rotors are cast from a high carbon G4000 grey cast iron. These work well with a pad designed to operate using abrasive friction, such that the rotor is sacrificial just like the pad.
    Some sintered metal (motorcycle) type pads work well with steel rotors, but conventional automotive pads need a more porous material, like grey iron.
  13. #11
    Jul 2005
    UK
    956
    20
    150
    I needed new Discs and Pads for my Vauxhall Astra recently .
    Found these on Fleabay , bought and fitted a set . Double, Vented, pads included and fast Delivery by courier . Run-out when fitted not measurable . Spoke to the vendor, available for most cars .
    Are there not such items available in USA prompting you to MAKE them?
    http://www.ebay.co.uk/itm/VAUXHALL-A...item45ef61592b
    Davycrocket
  14. #12
    17,106
    7259
    5362
    Quote Originally Posted by davycrocket View Post
    Davycrocket
    Most assuredly.
    The US equivalent of that Sterling price HERE gets a new set, and down the street on walk-in, not off ePray.
    Rebuilds cheaper yet.
    That's why I said use whatever the donor axle is fitted for.
    Now if MAKING the axles....... not even the major makers do that.
    Most buy 'em in from Eaton, Dana and such .. who buy the bearings from... and disks or drums from ... yadda yadda..
    Have to be a good reason to make yer own of anything in million-plus units a year volume production instead of picking up a parts catalog, a pint, and yer readin' glasses....
    Or Go ogle...
    Bill
  15. #13
    Jul 2011
    Lac Du Bonnet,Manitoba
    637
    60
    72
    i would look at snowmobile rotors and modify them to work.to think a 600 cc sled weighs 500 plus pounds,will go 80 mph and stop on a dime if track is studded.many atv rotors fit the wheel hub bolt pattern,so finding something that works would be easy.
  16. #14
    May 2011
    Nova Scotia
    386
    246
    155
    Motorcycles (and maybe ATVs) use 410/416 SS. Doesn't rust, and can be held on a magnetic chuck for grinding the faces.
    Made one a few years back, could almost do stoppies with it...
  17. Likes Laurentian liked this post
  18. #15
    Mar 2011
    Middleburg, Florida, USA
    396
    21
    77
    (coming from years of working on bikes of all kinds) It might be worth it to come up with a way to mount a motorcycle style disk to the hub or axle. You can find small Jap bike calipers dirt cheap. Would be easier to find a hub-bolt pattern of an appropriate size and either fit it to the hubs you're using, or machine a hub to mount it to. Lots available, solid, vented, slotted, floating, multiple material types... Find a local bike bone yard and pick a standard bike somewhere in the 650cc range. Front brakes, some had dual disk. You'll find calipers from single piston barely an inch diameter up to 8 piston banana, definitely something that will fit your application.
    Lots to designing brakes, you have to take into account the calipers you'll use, diameter, thickness, piston travel, master cylinder volume and effective stroke, etc. MUCH easier to repurpose something that engineers have already developed and tested on the road for decades. Boneyard could turn up a dual disk, dual piston caliper setup and the required master cylinder. You may need to spring for a rebuild kit, but they're on the order of $10-$20 and anyone capable of doing the rest of what you're doing could handle the rebuild. PLUS, being for a wet purpose like you're after, you could use the SS rotors from a bike and not have to worry about rust. Even if it wouldn't be structurally compromising, think about wet rust slinging on your paint...
  19. Likes 77ironhead liked this post
  20. #16
    Jan 2007
    Flushing/Flint, Michigan
    6,181
    246
    5004
    Quote Originally Posted by autofrite View Post
    You must have much bigger dimes up there. Lock the track yes, stopping seems to take a whole lot longer, at least until you nail the nearest tree.
    Then you can stop on a dime. (Oh, I hate it when that happens)
    Bob
  21. #17
    May 2011
    Nova Scotia
    386
    246
    155
    Quote Originally Posted by Trip59 View Post
    Never mind structure integrity or slinging rust, surface will negate ANY friction the first few times you hit the brakes, until it rubs off.
    Yes, that's experience talking... Younger and dumber days.
  22. #18
    Mar 2011
    396
    21
    77
    Quote Originally Posted by Sean the Dog View Post
    I was referring to the crap inside a normal rotor from a car, between the surfaces, on the ribs and whatnot of a non-solid rotor
  23. #19
    Aug 2010
    Minnesota
    1,372
    128
    1042
    It really depends on the pads... if using regular organic pads then ductile iron is a suitable choice... when using sintered metal pads there are some trace metals like lead that act as a lubricant and reduce breaking force, and low 1000 series metals are better. We just built some brake rotors for a project using sintered metal pads and 1045 steel rotors.
  24. #20
    Aug 2008
    Sussex, England
    3,046
    9
    596
    Not forgetting that the whole stopping process produces a considerable thermal variation around the disc. Real hot on the working part directly under the pads and getting cooler as you go round the disc to a minimum a little before it hits the pads. Plus a radial variation from inside to outside too. Pretty effective for making the thing twist and bend if the wrong sort of, or maybe any, stresses were locked into the parent material when it was produced. Twisty discs are less than ideal if you want to stop safely.
    Such effects are one reason for the modern fashion of mounting the larger sort of motorcycle disc brakes via loose(ish) bobbins so the whole thing can move more or less together rather than straining against the solid hub via the fixing bolts.
    Clive
