What kind of metal to use for salt water?
gr8life
Cast Iron
Dec 9, 2007
Las Vegas Nevada
I am in the process of making a fitting to keep a reserve diving tank attached to the main diving tank. Think of this as a quick change tool post for underwater use. First I thought alum. anodized, no good the ano. will wear off. Next thought of chrome plate, same problem. Should I use stainless and if so what am I looking for. New problem hope there is someone here who knows.
thanks
ed
I'm not sure what you mean by "quick-change" but if this is something that is threaded and going to be screwed and unscrewed often then stainless is only an option if that mating parts are NOT stainless. Stainless on stainless threads will gall up and seize in short order if you're not careful. If this is the case then brass would be a good candidate.
My first choice would be 316 SS. Readily available, good for corrosion resistance, sometimes called "marine grade stainless". Welds fine.
Be forewarned, you CANNOT let a cutting tool rub on the surface. If it's not cutting it will work harden the surface, and destroy the cutting edge.
Do not let it contact other metals, especially Aluminum, galvanic corrosion will be a problem. Use an insulator between dis-similar metals.
Same trouble with stainless on stainless.
This is 2 mating dove tails like a quick change tool post. The tanks are aluminum painted or powder coated.
ed
I would make the dovetail Male out of 300 series stainless.
Make the Female out of brass / bronze / tobin-bronze / what-have-you.
3 to 4 thou clearance....any locking threads still need to be
one of each as well.
Regards
M1M
Alloy 903 bronze is listed as being particularly resistant to saltwater exposure. It's weldable, if that matters.
I haven't used it, since I don't do any saltwater stuff.
- Leigh
Some of the better alloys will hold up for a long time if well anodized. Failing that some of the better enginering plastics are vertualy imune from corrosion, just may swell a small fration. There also a lot nearer netural bouancy.
Why not use what they use on most saltwater boats for valves and fittings: LG2 bronze. It's considered pressure tight for castings and machines really well. If it's an application requiring great hardness as well as corrosion resistance then opt for AB2 aluminium bronze instead although that would be tough to machine.
Delrin or a bronze alloy.
If you use stainless, its eventually going to come in contact with the aluminum tank and cause the tank to corrode.
Regards
M1M
I agree with this. Dissimilar metals will be strong enough for almost any load but resist galling when the members slide against each other.
Anodizing will not wear of aluminum and as mentioned some alloys are very good for saltwater exposure; after all diving tanks ar made from aluminum and so are boats.
Make the receiver out of aluminum and the insert out of Delrin which does not absorb water; actually the insert could be aluminum with Delrin inserts for the contact areas on the receiver.
Since your talking dovetails I don't see a problem with both metals being the same. I may be best to use one of the bronze alloys suggested. The clamping system could be of the same material.
Just to clarify there is little stress on this attachment. The current operation uses a strap which is clumsy and takes too long to hook up. The only thing he is looking for is a faster system.
thanks for all the info.
ed
