Howdy,
I want to make some rollers to help in moving logs. I'm gonna pull the logs over the rear of the flatbed trailer with a winch. The rollers will be arranged in a shallow V to help control the log and keep it loading straight and not sliding off one side or the other. Kinda like a boat trailer keel roller.
The logs will weigh up to 4000 pounds, though more often half that. I'm thinking of using schedule 40 3" pipe with solid steel plugs welded in each end and that plug turning on a 3/4" bolt at each end for a spindle. I'll turn the bolt down just enough to clean the thread off and bore the end plugs to fit. The bolt will screw into the bracket that the rollers ride in. Each roller will be 12-18" long. Does what I've described sound strong enough for the 18" length? Seems so to me but I'd just as soon not do this twice.
Thanks for your help.
