What is this Major Spline Diameter?
Results 1 to 7 of 7
    Jun 2005
    724
    7
    45
    Default What is this Major Spline Diameter?
    Spline data says:
    External Spline to fit internal stub tooth spline
    Flat root-Side fit
    12 Teeth 32/64 Pitch
    .375 Pitch Diameter-30' Pressure
    angle per ANSI B92.2-1996
    Guys over at the gear house are telling me to turn them to .405/.406
    When I calculate per the handbook I am coming out with a number about .004 smaller.I'm sure these guys are right as they do this kind of stuff all day long but since I have never used this place before I want to be certain.
    Anyone know what the major diameter should be?
    May 2003
    Iowa
    10,073
    3194
    3867
    Download this as a trial version.
    Involute Gear and Spline Software
    JR
    Sep 2006
    SE PA, Philly
    5,125
    923
    1592
    Quote Originally Posted by Metal Slave View Post
    Spline data says:
    Flat root-Side fit
    First, Isn't SAE B92.2M for metric? I think that the spec you want is SAE B92.1, which is in inch measure.
    I think that the pressure angle is 30° , not 30'. (to get the degree sign, hold down the alt key and type 0176 on the numeric keypad).
    For flat root, side fit, 30° PA, 12 teeth, 0.375 pitch diameter,
    D=N/P, or so diametral pitch is 32 consistent with your pitch and stub pitch diameters of 32/64, consistent with the spec.
    The major diameter for an external spline is
    Do = (N+1)/P = 0.4063" consistent with your calculation.
    There is "Form Diameter" and clearance (Cf=0.001D, or 0.0041 in this case), so check the spec and get the experts here to confirm, but I think that you got your OD right and it should be 0.406. To check, the internal spline major diameter (root) I calculate for this setup is:
    Dri = (N+1.35)/P = 0.4172. Your external spline OD of 0.4063", plus the tolerance of 0.0041, gives you 0.4104", which is less than 0.4172 by 0.0068 inches. That is, you have 3 thousandths clearance on this unit. I can't see why you'd use less than 0.406 on the OD.
    But check with experts. I'd been researching involute splines for a drill press quill. My source was page 2071 et seq. of Modern Machine Shop's Handbook for the Metalworking Trades, and this book cites the 92.1 specification.
    J
    Sep 2006
    SE PA, Philly
    5,125
    923
    1592
    Quote Originally Posted by JRIowa View Post
    JR
    Eval version diametral pitch must be less than 27 or some such. 32/64 not allowed!
    Mar 2003
    Vermont
    443
    93
    90
    Default per ANSI B92.1
    .392-.406__________________________
    Jun 2005
    724
    7
    45
    Thanks guys
    The spec is B92.1,I must have typed it in wrong
    Jun 2005
    724
    7
    45
    Still a little confused though as the formula I have for a Flat root Side Fit shows
    N/P + .8/P -.004
    For Fillet Root Side Fit it shows N+1/P
    Wondering if my handbook is outdated?
