What's the application of 5/16 40tpi tap
Community On The Web
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Like Tree28Likes
Thread: What's the application of 5/16 40tpi tap
    lowCountryCamo's Avatar
    lowCountryCamo is online now Stainless
    Jan 2012
    Savannah, Georgia, USA
    1,054
    Default What's the application of 5/16 40tpi tap
    I bought a box of tooling from an old machinist. In that I found a 5/16 by 40 tpi. Is there a special application of a tap that size? Maybe for chasing mic treads or some such?
    J Henricksen is offline Stainless
    Sep 2003
    Roscoe, Illinois
    1,469
    The screw in my small boring head has a 5/16-40 thread. Make a spare nut for one if you needed
    Bobw likes this.
    davycrocket's Avatar
    davycrocket is offline Hot Rolled
    Jul 2005
    UK
    956
    5/16" x 40 is a model emgineering (ME) thread in UK
    It was designed a long time ago to put a thread in thin wall tubing .
    It comes in a whole pile of sizes . and there are also 32 TPI in the ME range .
    The range is from 1/8" right up to 1/2"
    ME Tapping Drills Chart | Drill Sizes | Model Engineer Thread
    Smrtman5 is offline Cast Iron
    Apr 2011
    NJ, USA
    440
    IIRC an inch mic thread is 1/4-80. Theres a lot of fun threads out there, i found a couple of .570 -32 in a drawer at work. I dont know any specific uses for a 5/16-40 tho.
    aerodark's Avatar
    aerodark is offline Titanium
    Feb 2008
    Kirkland, WA USA
    2,554
    Quote Originally Posted by Smrtman5 View Post
    That pitch would render a rather strange micrometer barrel: .0125 advance per full revolution. Maybe you were thinking 1/4-40?
    lowCountryCamo likes this.
    kenh is online now Titanium
    Oct 2003
    Bonners Ferry, Id
    2,629
    5-40 tpi shows up in gun cleaning rods, also a 7-32.
    Remington has used 30 tpi.
    I made a 9/32- 30 screw for a gun smithe buddy.
    jim rozen is offline Diamond
    Feb 2004
    peekskill, NY
    22,012
    Electronics parts have threads of that flavor.
    Connector threads, switch barrel threads, etc.
    stephen thomas is offline Diamond
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    8,653
    I just made a bunch of locks for a specialty application that had combination keys. The mic barrels on the keys were 1/4" - 40. 'Course that was my choice. I'll speculate that a 40tpi tap is just often chosen for "special" apps where the maker/designer wants to control motion or position in a very small increment that is familiar, like the common micrometer thread; and not too much force is required.
    smt
    RebHawk's Avatar
    RebHawk is offline Stainless
    Apr 2011
    Boone, North Carolina
    1,002
    Quote Originally Posted by lowCountryCamo View Post
    If the "old machinist" hasn't passed, you might ask him. Could be for an interesting application none of us would think of...
    Regards,
    --Lee
    CalG is online now Diamond
    Dec 2008
    Vt USA
    4,279
    40tpi does lend it's self to "micrometer" type application. With each turn of the screw effecting a .025" translation.
    Something we all should be quite familiar with...Unless one has never looked past the LCD display ;-)
  11. #11
    James H Clark is offline Hot Rolled
    May 2011
    southern in.
    682
    Instrument makers. Years ago, I bought at auction a small box of oddball taps that came from an instrument company. Most of them were extrafine threads.
    JH
  12. #12
    Nov 2007
    marysville ohio
    4,854
    I have seen it on some medical stuff and also on some types of magnetic sensors.
  13. #13
    Aug 2006
    Hesperia, SoCal
    4,369
    ....and a differrential screw having both a right hand 40TPI and a left hand 25TPI, gives an advancement of 0.001" per revolution.
    Mark the dial with 200 increments, (or mic barrel with vernier) for 0.000005". Requires a steady touch if you expect repeatability...........
    Bob
    Ron Hofer likes this.
  14. #14
    Jun 2001
    8,653
    I use differential screws for the adjusters on my (woodworking) planes. The inherent problem with a differential screw is how much space or displacement of two of the components together is required for any sort of distance travel of the third. In your example, in 25 turns, one component would move into another 1 inch, which moving out of the third 5/8" (25/40"); or IOW carrying the traveler 3/8" in 25 turns or .015"/rev. Effective tpi 66.66.
    So, to carry a traveler a full inch of travel, the 25tpi section needs to be nearly 3" long and the 40 tpi section almost an additional 2" (15/8"). If you get down to .001/ rev resolution, the component threads get quite long to have the option of moving a traveler say 1".
    Edited: My example assumes both threads the same hand, for differential motion. Bob, I just re-read your spec, one LH and the other RH and as far as the cases I can come up with, this would be a compound thread leading to 1-5/8" displacement of the traveler in one direction with 25 turns. Effectively 15.385 tpi. But again, most of the mechanical arrangements I've considered were to effect differential motion in the stem of a wood plane adjuster. So there may be mechanical options I have not considered. I know you are a whizz at some of this stuff, so a diagram might help.
    smt
  15. #15
    spope14 is offline Stainless
    Jan 2004
    Claremont, NH
    1,638
    measurement applications. Thought it may be a glow plug tap for larger engines, but not sure now.
  16. #16
    gmatov is offline Diamond
    Feb 2006
    SW PA
    5,914
    Lot of ado about nothing. You can't say "This thread is useful, this one is not." You are not the Head Mother Fucker in Charge.
    Corps used to come up with proprietary threads, after they standardized.
    I have, I think, a 128 TPI tap. Feels like a poorly finished turning. But it is indeed a tap. Was there a need for it? Obviously there was, or it would have never been made. It HAS been used mre than once, so, once upon a time, it was useful, and possibly even a standard size. For what, I don't know.
    That there IS such is proof that there WAS a need . It is not a one off.
    George
  17. #17
    hickstick_10 is offline Stainless
    Oct 2009
    BC Canada
    1,189
    Getting great wifi from that bar stool I see
    daredo222 and machtool like this.
  18. #18
    rcoope's Avatar
    rcoope is offline Cast Iron
    Sep 2010
    Vancouver Canada
    327
    Here's some modern examples of the fine stuff: Thorlabs - Adjustment Screws . They're used a lot on mirror mounts and the like where you can get very fine accuracy because you're perturbing an laser beam or something at an angle. For optical scale direct movements you need differential threads or some fancy flexure thingy. They have the taps too: Thorlabs - Drill and Tap Kits
    RC
  19. #19
    Apr 2011
    NJ, USA
    440
    Quote Originally Posted by aerodark View Post
    Haha, youre absolutely right, that would make for a funny micrometer. I sure hope i was thinking 1/4-40 lol
  20. #20
    crossthread's Avatar
    crossthread is offline Stainless
    Aug 2004
    Richmond,VA,USA
    1,466
    In an LCSmith double barrel shotgun there is a replaceable firing pin bushing that has that thread. Only time I have ever used it.
