I've heard people say superglue works for a long time now but i haven't have verry good results. I'm trying to cut parts out of 0.200in thick aluminum plate.(I'm hoping I can use the same adhesive for carbon fiber and g10 plates as well.) I used a couple superglue brands, Gorilla glue, a couple different Cyanoacrylates' from hobby stores, with accelerator and I keep knocking the sheet off (aluminum sheet sanded with 400 grit to an aluminum plate , also sanded, both cleaned really well) with an 1/8in end mill.
If anyone has suggestions of the brand \ part number for something that works well I'd really appreciate it.
I would really love to use coolant with these smaller bits especially , if you know if coolant will be ok or not I'd appreciate that info as well, thanks.
