metalmagpie
Titanium
- May 22, 2006
- Seattle
I'm thinking of a roller built on the lines of a sheet metal slip roll only quite a bit heavier. Three rolls about 12" wide somewhere 3-4" diameter. I used to try to use a 22 gauge slip roll with thicker material than it was designed for but the gears only touched on their tips and it didn't work well. A design goal is to have a gear train which allows the rolls to be opened way up but still have the drive gears perfectly in mesh. This is the scheme (drawing copied from the Internet in 2017):
I purchased a lot of machinery bits and pieces containing a lot of gears today. I believe I can find 4 gears of the same diametral pitch 3 of which have the same number of teeth.
I would like to hear from people who have made a build similar to this. I am not sure my design chops are strong enough for this project.
If you have any ideas or experiences please share them.
metalmagpie
metalmagpie
