What's the application of 5/16 40tpi tap
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
    Jan 2012
    Savannah, Georgia, USA
    1,643
    2603
    597
    Default What's the application of 5/16 40tpi tap
    I bought a box of tooling from an old machinist. In that I found a 5/16 by 40 tpi. Is there a special application of a tap that size? Maybe for chasing mic treads or some such?
    Sep 2003
    Roscoe, Illinois
    1,506
    43
    The screw in my small boring head has a 5/16-40 thread. Make a spare nut for one if you needed
  3. Likes Bobw liked this post
    Jul 2005
    UK
    956
    20
    150
    5/16" x 40 is a model emgineering (ME) thread in UK
    It was designed a long time ago to put a thread in thin wall tubing .
    It comes in a whole pile of sizes . and there are also 32 TPI in the ME range .
    The range is from 1/8" right up to 1/2"
    ME Tapping Drills Chart | Drill Sizes | Model Engineer Thread
    Apr 2011
    NJ, USA
    468
    107
    103
    IIRC an inch mic thread is 1/4-80. Theres a lot of fun threads out there, i found a couple of .570 -32 in a drawer at work. I dont know any specific uses for a 5/16-40 tho.
    Feb 2008
    Washington
    2,838
    Quote Originally Posted by Smrtman5 View Post
    That pitch would render a rather strange micrometer barrel: .0125 advance per full revolution. Maybe you were thinking 1/4-40?
  7. Likes lowCountryCamo, The real Leigh liked this post
  8. #6
    Oct 2003
    Bonners Ferry, Id
    2,875
    573
    372
    5-40 tpi shows up in gun cleaning rods, also a 7-32.
    Remington has used 30 tpi.
    I made a 9/32- 30 screw for a gun smithe buddy.
  9. #7
    Feb 2004
    peekskill, NY
    23,728
    3905
    Electronics parts have threads of that flavor.
    Connector threads, switch barrel threads, etc.
  10. #8
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    10,969
    4075
    3797
    I just made a bunch of locks for a specialty application that had combination keys. The mic barrels on the keys were 1/4" - 40. 'Course that was my choice. I'll speculate that a 40tpi tap is just often chosen for "special" apps where the maker/designer wants to control motion or position in a very small increment that is familiar, like the common micrometer thread; and not too much force is required.
    smt
  11. #9
    Apr 2011
    Boone, North Carolina
    1,000
    143
    802
    Quote Originally Posted by lowCountryCamo View Post
    If the "old machinist" hasn't passed, you might ask him. Could be for an interesting application none of us would think of...
    Regards,
    --Lee
  12. Likes lowCountryCamo liked this post
  13. #10
    Dec 2008
    Vt USA
    6,008
    531
    1840
    40tpi does lend it's self to "micrometer" type application. With each turn of the screw effecting a .025" translation.
    Something we all should be quite familiar with...Unless one has never looked past the LCD display ;-)
  14. #11
    May 2011
    southern in.
    1,283
    1694
    332
    Instrument makers. Years ago, I bought at auction a small box of oddball taps that came from an instrument company. Most of them were extrafine threads.
    JH
  15. #12
    Nov 2007
    marysville ohio
    8,672
    2453
    5514
    I have seen it on some medical stuff and also on some types of magnetic sensors.
  16. #13
    Aug 2006
    Hesperia, SoCal
    4,369
    987
    632
    ....and a differrential screw having both a right hand 40TPI and a left hand 25TPI, gives an advancement of 0.001" per revolution.
    Mark the dial with 200 increments, (or mic barrel with vernier) for 0.000005". Requires a steady touch if you expect repeatability...........
    Bob
  17. Likes Ron Hofer liked this post
  18. #14
    Jun 2001
    10,969
    4075
    3797
    I use differential screws for the adjusters on my (woodworking) planes. The inherent problem with a differential screw is how much space or displacement of two of the components together is required for any sort of distance travel of the third. In your example, in 25 turns, one component would move into another 1 inch, which moving out of the third 5/8" (25/40"); or IOW carrying the traveler 3/8" in 25 turns or .015"/rev. Effective tpi 66.66.
    So, to carry a traveler a full inch of travel, the 25tpi section needs to be nearly 3" long and the 40 tpi section almost an additional 2" (15/8"). If you get down to .001/ rev resolution, the component threads get quite long to have the option of moving a traveler say 1".
    Edited: My example assumes both threads the same hand, for differential motion. Bob, I just re-read your spec, one LH and the other RH and as far as the cases I can come up with, this would be a compound thread leading to 1-5/8" displacement of the traveler in one direction with 25 turns. Effectively 15.385 tpi. But again, most of the mechanical arrangements I've considered were to effect differential motion in the stem of a wood plane adjuster. So there may be mechanical options I have not considered. I know you are a whizz at some of this stuff, so a diagram might help.
    smt
  19. #15
    Jan 2004
    Claremont, NH
    1,639
    9
    49
    measurement applications. Thought it may be a glow plug tap for larger engines, but not sure now.
  20. #16
    Feb 2006
    SW PA
    6,024
    1266
    726
    Lot of ado about nothing. You can't say "This thread is useful, this one is not." You are not the Head Mother Fucker in Charge.
    Corps used to come up with proprietary threads, after they standardized.
    I have, I think, a 128 TPI tap. Feels like a poorly finished turning. But it is indeed a tap. Was there a need for it? Obviously there was, or it would have never been made. It HAS been used mre than once, so, once upon a time, it was useful, and possibly even a standard size. For what, I don't know.
    That there IS such is proof that there WAS a need . It is not a one off.
    George
  21. #17
    Oct 2009
    BC Canada
    1,227
    151
    587
    Getting great wifi from that bar stool I see
  22. Likes machtool, daredo222, thermite, Oldwrench liked this post
  23. #18
    Sep 2010
    Vancouver Canada
    658
    429
    208
    Here's some modern examples of the fine stuff: Thorlabs - Adjustment Screws . They're used a lot on mirror mounts and the like where you can get very fine accuracy because you're perturbing an laser beam or something at an angle. For optical scale direct movements you need differential threads or some fancy flexure thingy. They have the taps too: Thorlabs - Drill and Tap Kits
    RC
  24. Likes lowCountryCamo liked this post
  25. #19
    Apr 2011
    NJ, USA
    468
    107
    103
    Quote Originally Posted by aerodark View Post
    Haha, youre absolutely right, that would make for a funny micrometer. I sure hope i was thinking 1/4-40 lol
  26. #20
    Aug 2004
    Virginia
    1,965
    147
    664
    In an LCSmith double barrel shotgun there is a replaceable firing pin bushing that has that thread. Only time I have ever used it.
