Where to buy babbitt?
Results 1 to 12 of 12
    Oct 2004
    canon city CO
    89
    Default Where to buy babbitt?
    Does anyone have any idea where I can buy Babbitt bar stock? I am wanting to buy some "super tough" and "heavy pressure" babbitt, but all I can find on the internet is chunks that you have to melt into bars? Any info will be greatly appreciated Thanks
    Mar 2008
    Reno, Nevada
    511
    16
    26
    You might try NF Metals in Seattle.
    http://www.nfmetals.com/
    Mar 2008
    Livonia, MI
    6
    all my babbitt came from ebay...
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    You won't find babbit barstock. It's available only in ingot form. You have to cast your shape and machine it from there. That's OK Babbitt melts at a low temp (470F or so). Cast it in a suitable can and peel off the can after it cools. I used aluminum tumblers back in the day. The casting just fell out thank to the taper. You do have to keep the head of the casting molton until the body solidifies so it doesn't pipe.
    If you have a bunch of items like bushing etc, make up a permanent mold Be sure to incorporate draft in any cores.
    There's been many a babbitt bushing cast in a permanent metal mold and sized by forcing it through a soft steel polished die with an arbor press. All that remains is machining the bore. You might think you could swage this too but the OD will inevitably expand and the swages metal's increase in hardness defeats the primatry function of babbitt.
  5. Likes pianoman8t8 liked this post
    Dec 2005
    Germany
    630
    43
    Hy,
    Ebay is a relatively cheap source of Babbitt in one or two pound ingots, people who don´t know use them as paperweights.
    Some of them are marked with pround and beautiful writings or pictures from the smelter who made them. Its a shame to cast them...
    Silicon forms will withstand the melting temperature and the parts are easy to take out afterwards. In case you use old stock, be careful to collect the shavings. They may contain arsenic and cadmium. Those two metals were used to reduce shrinkage and ascertain a more rigid alloy with greater wear resistance. In case you need a crude how too, look there:
    http://members.optusnet.com.au/terry...RepairPg1.html
    He´s not a pro but he does some mighty fine work...
    And here´s an old book, maybe interesting:
    http://www.metalwebnews.org/ftp/bearing-book.pdf
    Greetings,
    Johann
    Apr 2002
    Webster, Ma. USA
    673
    9
    19
    I've got 2 ingots of Tuftin hi-test nickel alloy. Pm me, we can discuss it.
    Jul 2007
    central WI
    1,135
    24
    153
    When it matters to have the best quality , I order from McMaster Carr .
    They sell high speed & low speed Babbitt in ingots .
    I re did the babbits on my 24" wood planer in 1984 . This machine has a cutterhead that runs at 6000 rpm . I use drip oilers and am glad I did not cheap out on the quality .
    Even though I put wear shims on the split lines ,I have not had to adjust anything .
    Something to consider : every time you re melt Babbitt , some of the antimony gasses off , and degrades the alloy . So when someone sells me some old bearing boxes , I cast it into bars and stamp " LS BABB " . I sometime use this when I cast the shop lead hammers , to make them a bit harder .
    Pretty hard to tell the grade just by looking at them , but good Bab will break cleanly when bent in a press. Lead can be almost bent in half without breaking .
    The best quality Bab has no lead at all in it .
    FBBob
  9. #8
    Mar 2008
    Reno, Nevada
    511
    16
    26
    Interesting. I also have an old 24" wood planer that I'm going to re-babbitt. Mine has "The Porter 24" cast into the front of the frame but there doesn't seem to be much available info on the company. I don't think it's related at all to the more well known Porter-Cable company. It'll be my first babbitting project.
  10. #9
    Aug 2008
    Murfreesboro, TN. USA
    694
    133
    Ace Hardware sells babbit in small bars. Not sure what size bars but they look like maybe 1 lb bars and 5 lb bars.
  11. #10
    Mar 2009
    Brunswick Oh USA
    4,256
    4293
    2495
    Johann,
    Here's a neat little ingot I've had for ever. Just thought you and others would like to see it.
    Ray
  12. #11
    Jun 2006
    Spokane, WA
    574
    103
    "Interesting. I also have an old 24" wood planer that I'm going to re-babbitt. Mine has "The Porter 24" cast into the front of the frame but there doesn't seem to be much available info on the company."
    Everything you wanted to know about old woodworking machines is at owwm.com here's a link to the Porter info: http://www.owwm.com/mfgindex/detail.aspx?id=649&tab=4
    thnx, jack vines
  13. #12
    May 2006
    Longview,TX
    1,003
    6
    How much do you need? PM sent.
