Bill D
- Apr 1, 2004
- Modesto, CA USA
I bought a 14' vertical /horizontal bandsaw that will be used just vertically. This means no coolant is used so any thoughts on where to locate it. Can it be shoved tight to a wall at the back? I will be cutting nothing over 5-6 feet long at most.
Since it is on wheels I could pull it out and reconnect the coolant pump which has to be disconnected for vertical use. I suppose I could run dry air through the coolant ports to help cool the blade. probably a waste of time and blow metal shaving into the air for me to breathe.
Bill D.
Bill D.
