fubar62172
- Apr 2, 2010
- westport,ma
Hey Guys
I need to machine a profile out if a microscope slide pc of glass?
#1 What is best way to hold it because of how thin it is?
I was thinking double sided tape but what would be best way to remove it afterwards? Or some kind of vacuum set up
#2 Should I cut it in a water bath? Or just with coolant?
#3 I'm machining it on a Bridgeport retrofit and do not have high speeds will that be OK?
#4 I What would be the best tooling to use? I'll need appx a .062 corner rad
Thanks for your help
Mike
Mike
