its a osp 700 and u10...i need the memory to load bigger programs
i have fd1 and md1
the biggest i can fit in md1 is about 62k
Going of my own memory here, which by the way is WAAAY more expensive to upgrade, but I'll try.
You have fd1 and md1 (File directory and Memory directory) but that also means you have fd0 which is a storage space with much more memory(256k). The kicker is that if it's too much K then you can't transfer it to md1 (which I believe is 56k, but irrelevant if it's too small).
But you can run schedule programs from the main directory. I'm going to try to explain this, so try and keep up with crazy. In fd0 the Main PROGRAM.MIN will be
your program. In the main directory the scheduled program will be SCHEDULE.SDF and will look like this;
SCHEDULE.SDF
PSELECT FD0:PROGRAM.MIN
END
at the end of
your (PROGRAM.MIN) program change the M2 to RTS
Here is where the voodoo really starts. Go to Auto mode and extend,extend until you see sp select (not program select, but same thing), press that, press* select and a list of scheduled programs arrives, select SCHEDULE.SDF. The screen wil be blank......press Cylce start....it will run the PROGRAM.MIN from the fd0, and be showing you
that program, and all the positions and active commands just like normal.
Note> same as dripping; feed hold works, everything works, mid-auto works, but if you reset it, it's the same as resetting a dripping program.
R
