Trboatworks
- Oct 23, 2010
- Maryland- USA
I have to make a 5" long bushing with ~3.5" bore and ~.1875 wall thickness.
Before I start cutting- am I facing a nightmare to spin this down on the lathe?
I have a length of 4.5" solid rod and am figuring to cut the bore in first than skim down the shell to size.
This is a rudder bushing which is going to be set with epoxy into a corrosion trashed aluminum rudder tube so I suppose the bore has to be good but the outer cut can be a bit wonky.
Any tips on setting up to support the work as I cut?
I am figuring on just chucking up a length, facing and boring to size then cutting the OD/parting off all with no tail stock.
I wonder if that damn slippery stuff will hold in the chuck for that much messing around..
Is stock such as this ever tapped and bolted to face plate for this sort of operation?
I think the job is a good candidate for a cast in place epoxy/graphite bush but the maker has grease grooves chopped all around the stock so that route is a no go.
Thanks all
Thanks all
