peter
Titanium
- Mar 20, 2001
- New England
This is continuation of past discussion. I had been asking for the best way to really lock down the brass jet or seat in an old castiron carb/mixer. I broke off 1/2 or 2/3 of the threads and dont want this thing to get sucked into the engine. Future removal is not a concern.
Some good ideas were suggested including general epoxy products like JB Weld. I am reluctant to use JB Weld type solution if applied to threads and shoulder only. it seems to thick. I am not going to bead blast of drill anchor holes either and I dont want any loose epoxy into the engine. Although, I do belive it would work based on advise presented.
My friend plays with firearms suggested I try Loctite Black Max 380. This is so strong it supposed to hold sights on a gun bbl. And unlike std loctite is suggested stored in refigerator. Resists solvents. I got some and think i will give it a try, while i was there I also got a cheeper bottle of Loctite 262. The 262 sounds like the recommended product for hi-temp and gasoline exposure. In my case hi-temp is not very high practically speaking 200deg F, higher if things go seriously wrong.
Any comments on Black Max 380 vs 262 ?
