Hi guys i need a little help with wiring a Gorton milling machine to a static phase converter. The mill is 2 hp and was wired for 240 volt 3 phase, and is equipped with a magnetic switch and overload heaters my problem is the heater are cutting power to the machine it only runs for 30 seconds or so before the reset button kicks off. Do 3 phase motors draw more amps on static phase converters ? and could i just bypass the heaters all together ?
