Taps and Threading tools
Results 1 to 14 of 14
    Mar 2011
    Peoria, Illinois
    Default Taps and Threading tools
    I am trying to find documentation whether specification or process on the basis of GH and LH designations for machine thread taps. I have used them for years but never have found the practice defined and described. If anyone has come across this I would appreciate your input.
    May 2010
    Denmark
    17,291
    3574
    10307
    Quote Originally Posted by steven m stinson View Post
    Probably not exactly what you had in mind but this is what I came up with after Googling GH and LH designations for machine thread taps and GH designation for machine thread taps
    The Good, the Bad and the Retapped
    I'm not quite sure why you combine LH with GH as to my thinking RH (right hand) and LH (left hand) go more "together". GH is tolerances.
    Gordon
    May 2010
    Denmark
    17,291
    3574
    10307
    Surely some must know more about this than what I've written?
    Mar 2011
    Geneva Illinois USA
    4,791
    1887
    1785
    From MSC Big Book page 273:
    Example - 1⁄4-20 NC H3
    In addition to the nominal size and pitch of a tap, there is another important
    dimensional factor to be considered in selecting a ground thread tap. This is
    the H limit of the pitch diameter of a tap. H means (high) above basic pitch
    diameter(A "D" corresponds to metric threads). These tap limits have been
    established to provide a choice in the selection of the tap size best suited to
    produce the class of thread desired. The difference in size from one H limit to
    the next is 0.0005􀁷 increments for taps through 1" diameter. Sizes over 1"
    diameter are separated by .001􀁷 diameter increments. If the threads in the part
    are too loose, smaller numbers such as H1 or H2 are used. If the threads are
    too tight, the H limit number is increased. Proper selection of the H limit
    number ensures that the threads are within the tolerance required by the part
    print. Best rule of thumb: always select the largest “H” limit possible to achieve.
    Tom
    May 2010
    Denmark
    17,291
    3574
    10307
    Quote Originally Posted by TDegenhart View Post
    In addition to the nominal size and pitch of a tap, there is another important dimensional factor to be considered in selecting a ground thread tap. This is the H limit of the pitch diameter of a tap. H means (high) above basic pitch diameter(A "D" corresponds to metric threads). These tap limits have been established to provide a choice in the selection of the tap size best suited to produce the class of thread desired. The difference in size from one H limit to the next is 0.0005�� increments for taps through 1" diameter. Sizes over 1" diameter are separated by .001�� diameter increments. If the threads in the part are too loose, smaller numbers such as H1 or H2 are used. If the threads are too tight, the H limit number is increased. Proper selection of the H limit number ensures that the threads are within the tolerance required by the part print. Best rule of thumb: always select the largest “H” limit possible to achieve.
    Tom
    Tom, excellent I think many forget (or don't know?) that taps and dies can be bought with various tolerances just as threads have various tolerances. The vast majority of taps and dies are made to produce standard tolerances.
    These are 2A / 2B (external/internal) for UNC threads and 6g / 6H for metric threads.
    If you don't specify the tolerance on a thread then those tolerances are what you'll get.
    Mar 2007
    MA.
    103
    There is a good explanation in Mc Master Carr catalog for those that don't have a machinist handbook. I have used the oversize taps when heat treating is involved and with metals like Inconel and Colmonoy.
    McMaster-Carr
    Dick
    May 2010
    Denmark
    17,291
    3574
    10307
    I've been tidying up and found a small booklet (3x6" approx. and with 64 pages) I've had for years and can't remember where I got it.
    The name of it is PRESTO Engineers Cutting Tools, Counsellor Publication PC2/D and has a surprising amount of information. There are 7 pages dealing with tapping ranging from tap classes to reasons for tapping faults and failures to tapping speeds in various materials.
    It's a mine of useful information and a real handy pocket size.
    I can give the address of the company HQ etc. if anyone is interested but I haven't a clue if this booklet is still available.
    Nov 2004
    Viborg, Denmark, Europe
    861
    679
    462
    Here ya' go..
    Presto Counsellor
    Best regards
    Søren
    May 2009
    Canandaigua, NY, USA
    2,477
    104
    949
    There's a lot of info on-line that's either insufficient or clear as mud. The big thing to remember is not to confuse individual part (screw and nut) specifications with fit. You can buy taps in incremental sizes, and any given tap may give different size threads in different materials. This says nothing about fit. You can look in Machinery's Handbook and get the size limits for external screw threads. That doesn't tell you anything about fit either. Only when you combine the thread size resulting from the use of a certain size tap, with a certain size external screw thread, do you get a fit.
    May 2010
    Denmark
    17,291
    3574
    10307
    Quote Originally Posted by slnielsen View Post
    Here ya' go..
    Presto Counsellor
    Best regards
    Søren
    Great. If you're ever driving by stop in and we'll have a coffee
    Gordon
  11. #11
    May 2010
    Denmark
    17,291
    3574
    10307
    Quote Originally Posted by Conrad Hoffman View Post
    If that was meant to help it had the opposite effect on me
    You made things sound much more complicated than I previously thought they were
  12. #12
    Nov 2004
    861
    679
    462
    Quote Originally Posted by Gordon B. Clarke View Post
    Gordon
    Beware...
    I might hold you up on that one..
    Same here, if you ever get so far north as Viborg..
    Søren
  13. #13
    May 2010
    Denmark
    17,291
    3574
    10307
    Beware...
    Søren
    Wouldn't write it if I didn't mean it
    I do get to Viborg sometimes
  14. #14
    May 2009
    2,477
    104
    949
    Gordon, don't feel bad- things are more complicated than I thought too. I just went through this with a run of parts in a very expensive material where I missed the PD by a thou and it was too much.
    You can get the same or similar fits using all different size taps (the GL and GH numbers) if you combine the resulting threaded holes with different size externally threaded screws. It's the combination that matters. Fortunately people tend to stick with just a few popular combinations, but there's no law about it. For commercial hardware its a no-brainer, but for close fitted instrumentation screws and such the parts need to be specified correctly such that the resulting fit is what was desired.
