Results 1 to 7 of 7
    JimK is offline Diamond
    Apr 2003
    Berkeley Springs, WV, USA
    4,291
    On July 11, 1938 The National Machine Tool Builders Association Commettee on Milling Machine Nose Standardization approved as Standard the dimensions and configuration of milling machine spindles and arbors that we know as the No. 30, No. 40 and the No. 50 milling machine tapers.
    The construction was covered by U.S. Patent No. 1794361.
    There were six sizes proposed, No.'s 10 through 60 The No 10 MMT had a gauge diameter (big end) of 5/8 inch. The No. 20 was 7/8 inch.
    These sizes were not produced.
    The gauge diameters of the others are as follows:
    No. 30 1 1/4 in.
    No. 40 1 3/4 in
    No. 50 2 3/4 in.
    No. 60 4 1/4 in.
    All Tapers are of 3.500 in. per foot.
    Most of the dimensions are rather loosely toleranced. All are in Inch Measure.
    All Standard Spindle noses must project out from the column or head by a minimum amount and the outside diameter of the spindle nose is held to close tolerances.
    No. 30 O.D. - 2.7493-2.7488
    No. 40 O.D. - 3.4993-3.4988
    No. 50 O.D. - 5.0618-5.0613
    No. 60 O.D. - 8.7180-8.7185
    There are two spindle keys and they are specified as a tight fit in the spindle key slot.
    The key widths are:
    No 30 and No 40 - .6255-.6252
    No 50 - 1.0006-1.0002
    No 60 - 1.000-0.999
    There are 4 threaded holes equally spaced but at 45 degrees to the keys.
    No. 30 - 3/8-16 NC-2
    No. 40 - 1/2-13 NC-2
    No. 50 - 5/8-11 NC-2
    No. 60 - 3/4-10 NC=2
    Nose Projection from Column or head (minimum)
    No. 30 1/2 in.
    No. 40 5/8 in.
    No. 50 3/4 in.
    No. 60 1 1/2 in.
    The care taken with the configuration of the spindle nose is to allow large cutters (face mills) to be mounted directly on the front of the spindle without locating on the internal tapered surface.
    There are no tight tolerances on any dimension of the tapered part of the arbors or tool holders except for the 3.500 in. per foot taper. They must locate on the taper only.
    Drawbar threads are as follows:
    No. 30 1/2-13 NC-3
    No. 40 5/8-11 NC-3
    No. 50 1inch 8 NC-3
    No. 60 1 1/4-7 NC-3
    No, that is not a mis-print the drawbar threads are specified as a No. 3 (precision) fit.
    Dimensions Taken from The American Machinist's Handbook, Colvin and Stanley, Seventh Edition, 1940.
    Text mine
    Jim Kizale
    donie is offline Diamond
    May 2003
    4,157
    Good info Thanks!
    rst
    rst is offline Junior Member
    Oct 2003
    Canada
    very interesting. Thank you.
    I was asked last week what the R and the "8" mean in a R8 collet. I have asked several people so far, but not gotten any answers.
    Any help or direction where i could get help ??
    Thank you !
    Pali is offline Aluminum
    Feb 2007
    India
    141
    Post
    JimK,
    very interesting.
    I make the Arbors and Spindles in ISO tapers 30, 40 & 50 for Milling Machine Builders in India.
    we however work with metric, but originally they are all Inch dimensions.
    Thank you
    Pali
    Bangalore, India
    Feb 2007
    India
    141
    Jim if you could Scan a Copy of this info from the original book (1940), it would make a very good picture to hang on a wall of our shopfloor.
    We make Spindles and milling arbors with these Tapers, for the Indian Machine Tool Builders.
    Thank you and best regards
    Pali
    S_W_Bausch is online now Diamond
    Jan 2010
    Indianapolis, Indiana, USA
    4,598
    Pali,
    JimK hasn't posted to this site since 2006 (check his posts).
    However, at this moment, ebay has that exact book for sale, as a Buy It Now, for $29.95.
    American Machinists' Handbook + Shop Terms ~ 1940 | eBay
    If you desire that exact verbiage.
    The American Machinists Handbook was a competitor to Machinery's Handbook, which should have the same information.
    Old machinist handbooks are on ebay quite frequently. I suspect that a patient person could collect each year's book, spanning back several decades, if they so desired.
    mister honey's Avatar
    mister honey is online now Hot Rolled
    Feb 2005
    eastern blowville heights, ohio
    851
    IIRC, Jim Kizale passed several years ago.
    Mike
