Page 1 of 21 12311 ... LastLast
Results 1 to 20 of 419
Like Tree3Likes
Thread: 12 GA From Hell
    hubel458 is offline Cast Iron
    Mar 2006
    Brinton, MI
    332
    Post
    I'm a visiter here.Great site. I am visiting
    to tell about a project 2 others and I on
    AR forum are experimenting with.It is long
    12ga brass case, chambered in heavier stronger
    guns to get better than nitro express power.
    Much like the old paradox guns used in Africa
    years ago.Butwith a much stronger case. we made case by putting 12ga size rim on bmg brass.
    Other 2 guys put theirs on big Borchardt
    falling blocks and I put mine in a Savage 210
    12 ga action with heavy barrel and stock.
    The Savage has a big three lug bolt head, as
    shown in first picture next to an Enfield bolt.
    In 2nd pic is our case next to regular 12 ga
    case, which can also be fired in our
    chambers.Ed Hubel
    ytr17 likes this.
    MilGunsmith's Avatar
    MilGunsmith is online now Hot Rolled
    Mar 2006
    Branchville, NJ
    600
    Post
    Looks like an interesting project. Do you have a drawing/measurements of the case? How are you making the cases? Do you have any load data?
    Oct 2005
    Cincinnati
    111
    Post
    Hubel;
    That thing looks a lot like the old 8 bore and 4 bore guns I have seen at the Ohio Gun Collectors Shows. They are basicly huge shotgun shells, all brass, loaded with a single slug or shot. The guns I have seen are all beautifully made heavy custom double guns from England and the European mainland, built around the turn of the century (1900, not the last turn of the century). Some of the guns have rifled barrels, and some are smoothbore. Apparently big, dangerous game was shot at close range, well below 100 yards. Have fun with your project.
    Perk in Cincinnati
    Davy is offline Junior Member
    Jan 2006
    Post
    Here is a comparison of some sizes ..
    Davy
    Mar 2006
    Brinton, MI
    332
    Post
    Davy-There a bunch of us that are getting 4bore
    barrels made to set up some, with 4 bore
    cases we made from 20mm brass.We may have them going in a year or so.
    Milgunsmith--Case is max of 3.85 inches long.
    Rim is .880- base is .802- mouth is .770.
    I gotten 730 gr hard cast Dixie lead slug
    up to 2500fps at 30k psi.Rob has gotten a 750gr
    banded solid up to 3000 fps in his falling
    block.I've gotten a 327 gr sabot out at 3900.
    To put rim on cases we turn off old rim to bottom of extractor groove, and thread stub 5/8 x 24
    for premade rim that screws on with locktite.
    Here is picture of cases with threaded stub
    and premade rims along with 3
    different slugs in other cases.Ed
    Jan 2006
    Post
    Impressive to say the least! From both ends no doubt when you fire them!
    Davy
    Oct 2005
    Cincinnati
    111
    Post
    UF DA!
    My shoulder hurts already. Those four cases in the picture looks like full day's shooting!
    Perk in Cincinnati
    abarnsley is offline Titanium
    Mar 2005
    Palmer, Alaska
    2,334
    Post
    I would want a clarification from BATF&E
    http://en.wikipedia.org/wiki/Destructive_device
    Looks like a DD to me................If its rifled
    almost positivly a DD
    Mar 2006
    Brinton, MI
    332
    Post
    Not a dd as long as it is shotgun bore.
    otherwise there would be millions deer hunters
    with rifled shotgun barrels that hunt deer in
    shotgun only areas in a bind.
    This is as per title 18 GCA-- Sec 921--
    Part (a)-- Section 4-- Subsection (B)
    Shotgun calibers exempt.
    Then Subsection (C) exempts those that they
    determine are sporting like NE cases,
    Nyati,Trex, JDJ big bores, and others
    who have applied for sporting exemtion like
    they did on AR for the 550 Magnum and I did for
    my 700HE.Ed.
    jkilroy is online now Diamond
    Jul 2004
    Vicksburg, MS
    4,751
    Post
    I seriously doubt that the 12ga bore is exempt as a number. (.729 or 18.51mm) Does that mean I can take a 20mm round and neck it down to 18.51 and start blasting as you guys have? I will not be suprised when we find out you have had a visit from the BATF.
  11. #11
    Mar 2006
    Brinton, MI
    332
    Post
    jkilroy- No it must be a shotgun style case,
    same base as 12 ga to be called a 12 gauge...
    IE, a straight case. They have 2.5, 2.75,
    3.0, 3.5, and 3.75 inch 12 gauge cases
    and chambers. We have our barrels stamped
    12 GA 3 3/4. And they fire all lengths of 12 ga cases, and most 12 gauges now are made
    stamped with their length.Everybody is shooting all lengths of brass, plastic, paper,aluminum,
    12 ga stuff with regular slugs for smooth bore, rifled barrel slugs, high speed saboted loads, and they are all exempted.If it can fire any
    12ga case same or shorter, it's exempt..Ed.
  12. #12
    Jul 2004
    Vicksburg, MS
    4,751
    Post
    When you load a slug in there what are you using as a spacer. You aren't filling that up with powder are you? I might have to start working on one of these monsters, if for nothing else, to show to all of my daughters future boyfriends before they leave the house.
    metalmaster10 likes this.
  13. #13
    johnoder's Avatar
    johnoder is online now Diamond
    Jul 2004
    Houston, TX USA
    18,465
    Post
    Just so you can get the full "impact" of the above statements, 750gr at 3000FPS is 14,992 lb/ft, or say, 6000 more than a Weatherby 460!
    John
    R.G.B. likes this.
  14. #14
    Mar 2006
    Brinton, MI
    332
    Post
    jkilroy- johnoder--Actually 7500 more than what
    460 delivers over a chrono. As for powder,
    it can be loaded with shotgun powder and wads.
    Or like Rob and I do filled up with slow rifle
    powder. I use WC-860-872- etc surplus, that
    is only 4 bucks a lb.
    jkilroy- as for the dd discussion, DDs not
    illegal per se, as long as they get their 200
    bucks per item, and paperwork. And we asked
    if shotgun chambers can be lenthened for longer
    cases, and they said ok. Lot of guys are going to 3.5 magnum, where smith runs in a lengthening reamer. We asked if cases could be owned without tax if we made our own with lathe, if we
    had someone else make brass cases on a lathe,
    steel cases, aluminum cases, shotgun or rifle
    primer, if we made our own slugs, cast or swaged, they said ok...I am sure there are antis out
    there that don't like us having a hobby with
    that much freedom, but we are sure law
    trumps them.Ed.
  15. #15
    Jul 2004
    Vicksburg, MS
    4,751
    Post
    And you are shooting this monster from the shoulder? REALLY Big brake on the end? Post some pics of the thing man, I have GOT to see one of these.
  16. #16
    Mar 2006
    Brinton, MI
    332
    Post
    jkilroy- No brake just weight, balance and
    31 inch long barrel.Here is picture of my
    Savage 210, with heavy barrel and weighted
    stock. 2nd picture is Rob's nice African style
    Borchardt falling block. And both have real
    thick recoil pads.Ed
  17. #17
    Mar 2006
    Brinton, MI
    332
    Post
    Here is picture a bmg case with rim turned off
    and stub threaded for the 12ga size rims
    shown in picture. Also shown are 3 cases with different slugs in them.Ed
  18. #18
    John in MA's Avatar
    John in MA is offline Titanium
    Apr 2005
    MA, USA
    2,059
    Post
    OK, I admit it. I'm not man enough for that gun.
  19. #19
    jeffeosso is offline Hot Rolled
    Jan 2004
    Porter, Tx
    770
    Post
    Hey Ed,
    this is a darn good site... don't go scaring em with this big stuff... should warm them up with RNS' 550 mag or our 550express!!
    www.weaponsmith.com
  20. #20
    Mar 2006
    Brinton, MI
    332
    Post
    Hi Jeff-- Just getting the word out.Once
    we convince them that firing the big guns
    don't maim or kill they will ok. There
    is lotsa interest all over the
    net, that's for sure.When I formed
    the first 550 Magnum case
    for Neal(RNS) I really got you and him in
    wildcatting high gear.It is a really
    great hobby.Ed.
