milotrain
- Nov 10, 2010
- Los Angeles
In the case that you would predrill or prebore a chamber I'm assuming that the reamer must still enter "pilot first" or the drill/bore will be guiding the reamer. In that case aren't you simply drilling or boring a fairly shallow hole (should correspond to the distance of the back of the pilot to around 1/2 way up the shoulder in most cases) that would be opened up by the back of the reamer once you are at full depth? Or are most people dialing it in enough that they are comfortable boring the majority of the chamber and just finishing with a reamer being guided by the prebore?
Does any of this change if you are working in a steadyrest rather than through the headstock?
Thanks for the help.
