12 gauge gatling
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Dec 2008
    mayo, ireland
    13
    Default 12 gauge gatling
    been thinking now for a while about a 12 gauge style gatling gun, are ther any sites online tht id be able to get dwg, dxf, or solid models of the cam system, barrels ,carrier , and the locking cylinder, this is only aa hobby for me and it prob wont be used to fire, just wondering if it can be done. any of your tips on such a project would be great thanks
    Jun 2009
    Upper PA, displaced Alaskan
    10
    Maybe a scaled-up rework of one of the .22 kits. The cams could be problematic to ensure proper movement and clearance, but it at least gets you started on the concept.
    http://www.practicalmachinist.com/vb...un-127771.htmlThese fellows may have some input.
    Other than that, I've got nothing right now.
    Oct 2004
    Iowa
    2,945
    42
    294
    Default Well...
    Colin- if you actually built it to be suitable for firing (and I can't see a reason why you wouldn't), I'd like to see it fire...
    ...but I wouldn't want to be anywhere nearby...
    So take a good video, and post it on Youtube!
    May 2009
    South Australia
    103
    Should be handy when duck season is on.
    Rob
    Sep 2004
    NH
    1,014
    55
    I have had the same idea - I had accumulated a bunch of 12g barrels and receivers from the JC Higgins BA shotgun recall and wondered what I could do with them. One thing you need to consider is if it would be considered a destructive device by the ATF. The Streetsweeper shotgun, once available over the counter is now considered a destructive device and requires the tax stamp. Maybe a wheeled version would get around those restrictions but that is something you would have to take up with the ATF. It would be an incredible bit of firepower though.
    Jan 2003
    Jacksonville, Florida, USA
    2,324
    8
    Since his profile says he is in Ireland, he probably could care less what the ATF has to say about it.
    David from jax
    Sep 2004
    NH
    1,014
    55
    I guess the ATF would not be interested - go for it!
    May 2009
    SD
    105
    Its been done by someone here, maybe the member will chime in.....
    Sep 2006
    northern arizona
    101
    I started on a conversion for the 1919a4 sometime back but because of more pressing work that makes money it ended up on the back burner .
    Jun 2007
    New Zealand
    2,661
    28
    Quote Originally Posted by Gazz View Post
    Happen you're right ..... the IRA sure would be, though !
  11. #11
    Dec 2008
    mayo, ireland
    13
    Default ha ha
    did u not hear ther retired
  12. #12
    Aug 2005
    Puget Sound, Washington
    3,204
    31
    202
    Might be easier to build a simple array of semi-automatic shotguns on a rack and thread a cam shaft through the trigger guards attached to a hand crank. Depending on the alignment of the cam lobes it could fire in salvo or sequentially or sequential salvos.
  13. #13
    Apr 2009
    Bartley,NE
    123
    36
    27
    I made one several years ago but sold it. I made the wooden wheels and all. The magazine held 23 rounds and it had 6 barrels made from 1.25 by .75 DOM tube chambered with a Clymer chamber reamer. The bolts were made out of 1" grade 8 bolts turned down and firing pin hole drilled and case hardened in the rear with Casenite. Each barrel was threaded 1-1/4 left hand bolt thread with lengthening nuts to adjust the headspace for each individual barrel since each bolt was made for it's particular barrel. All lettered to match. I didn't have the convenience of a milling machine so the Dremel got a workout. The gear mechanism came out of a '24 Whippet car I believe and the hand crank from a butter churn. I don't have any plans as I did it all as I went. In the last picture you can see a bearing running against a slanted cam type thing. Each bolt moved along that until just before it fired, then the case hardened end of the bolt slid along several hand files that were welded together and brazed to the cam. The rate of fire was about 120 rounds a minute. My only flaw was that the extractor didn't have a strong enough spring and when the chambers got dirty the empty cases would stick and jam the unit. The entire gun was made from metal we had laying around the shop, mostly irrigation pump pieces such as column pipe, oil tube, bronze bushings and head nuts.
    Here's some pictures.
    Jim
    Attached Thumbnails Attached Thumbnails picture-2-011.jpg   picture-2-003.jpg   picture-2-009.jpg
  14. #14
    Apr 2009
    Bartley,NE
    123
    36
    27
    A few more picts.
    Jim
    Attached Thumbnails Attached Thumbnails picture-2-005.jpg   picture-2-004.jpg   picture-2-013.jpg   picture-2-010.jpg
  15. #15
    Sep 2007
    Spanish Springs, NV
    2,367
    155
    278
    That's audacious and ingenious. Gotta wipe coffee off the monitor now, the photo with it pointed towards a large playground set really tickled me!!
  16. #16
    Apr 2009
    Bartley,NE
    123
    36
    27
    LOL! Yes, the kids on my block are really docile.
    Jim
  17. #17
    Sep 2007
    Spanish Springs, NV
    2,367
    155
    278
    Default !
    LMAO! Dinner is ready, when playtime is over it's over!
  18. #18
    Aug 2008
    Californeeeah
    1,430
    40
    288
    That's a beautiful piece of work Jim!
  19. #19
    Dec 2008
    mayo, ireland
    13
    luv the pic's jim, did it take to long to build it
  20. #20
    Apr 2009
    Bartley,NE
    123
    36
    27
    Quote Originally Posted by colin_the_celt View Post
    It took roughly 6 months to make the gun, and 1 month for the wooden furniture. I test fired it in my shop with black powder loads. I suspended a plastic barrel filled with rags and pointed the gun at it and started cranking. The smoke was so dense that I couldn't see that the barrel had separated from the rope and fell to the floor. About 5 or so rounds went through the wall and impacted into the steel wheel of my '36 F-20 tractor. The loads were shot so it didn't hurt much except the wall it went through.
    Jim
