WTB #7-32 tap & die
if u have a tap ,it is not too much trouble to make ur own die ...had to do it for a 6x48 50 yrs ago ...learned that the die shud be near 100% full thrd ..was tough screwing on those .45 colt grips.watch the minor d. to acheive this ...just copy one of ur dies ...if u need hardening /temper info ,ask.....
best wishes
docn8as
A number 7-32 thread is used on scope mount for an early rifle. I found I could make the screw by adjusting a 6-32 die head to larger dimension (.151"). In restoring an antique gun, it is not proper to change thread sizes. Many early guns had odd/special threads. Purchased screws are usually a close approximation and have to be forced. Another hard item to find is die punches with serifs. Need those too. Thanks
Are not some bore brushes 7-32 also? It is not possible to use a #8 in some small cleaning rods and still maintain strength.
Cheers from Darkest California,
Ross
Thanks, Joe21 for the 7-32 die nuts. They worked fine and I finished making the three screws in less than 1 hour. Lots of great people out there still.
