Hi guys,
Anybody else ever done their 1911 rails with a surface grinder? (I had one. I had time. Etc.)
The reason I ask: I *know* I'm within .0005" in terms of side-to-side fit, and it does indeed slide very nicely, but it feels almost too smooth, if that makes any sense. It slides much easier than equivalent lapped slides do, even lapped or milled slides that are a little looser. (about a thou, instead of half thou.) I thought I'd overshot somehow, but I checked the fit a couple of different ways, and side to side, I'm within about .0005". I've got about .001" clearance vertically, against the bottom face of the slide, also ground in.
Huh???
Puzzled,
Brian
PS--> Next question: Has anybody ever thought to carve/engrave oil grooves into their slide rails? I started out as a jeweler, I've got the powered engraver and microscope to do it... I use Brian Enos' slide grease (to great effect) and I've started wondering if it'd be worth the bother to put oil grooves into the slide rails. Opinions?
(the same kind of grooves you see on scraped machine guide surfaces. Just a whole lot smaller.)
Huh???
Puzzled,
Brian
