Bob Itnyre
- Aug 10, 2002
- 29 Palms, CA
A friend of mine gave me this problem. If you’ve seen it please tell me where. I’ve searched without luck. Anyway, this was supposed to have been a problem at the Naval academy quite a few years ago.
You have four perfectly spherical cannon balls. Let’s say they are 12 inches in diameter. They could be any size as long as they are all the same. You place three of them on a flat surface, blocked, so they won’t roll and the three are all touching each other. Then you place the fourth one in the space at the top. All four are now touching each other. What would be the size of a smaller ball that could be placed in the center of the four, so that it touched all four balls and did not keep them from touching each other?
A couple of math teachers I know are wrestling with it, but I figure machinists do this stuff every day.
