Hi guys,
This started out as a scheme to help my cutter grinder guy stay in business, and that remains the ultimate goal, so with that in mind, let me ask a few questions.
I'm working on an 80% 1911, and have looked at some of the 0% cast frames.
This has caused me to wonder just what, exactly, Mr. Browning was smoking. To do the thing to print, you end up having to make a bunch of custom cutters, and even a few custom sized drills and/or reamers. My ponderments about just exactly *why* the thing is designed the way it is to the side, even with a modern 80% frame, you still need one custom dia. ball mill for the barrel bed, and a couple of hard-to-find-for-non-machinist drills and reamers.
With the increasing popularity of 80% frames, do you guys think it would be a viable proposition to set up a website to sell kits of all the various cutters you need to finish off a 1911? (AR's too, but that's easy) It's the weird custom cutters for the 1911 that are really hard to source. Brownells has some of them, but not the big ballmill for the barrel bed. (and they want a mint for what they do have.) So you get a kit with the .696" ball mill for the bed, the 4mm (.1575") drill/reamer combo for the hammer pin, and the #35 drill/reamer set for the sear pin. Plus options of the other weird sized reamers if you need them. (.1558?? WTF?? Good news is that 5/32 is within the tolerance band, but why spec a hole that isn't *any* standard drill size, for no apparent reason??! )
I was also thinking about doing the two little custom woodruff cutters that the 0% people need for doing the mag release and barrel bushing undercuts.
And then there's the .119" saw for doing the slide cuts. (.119? Really? Why couldn't it have been .125? 6 thou mattered that much???)
My inclination would be to do that one as a saw, but I've got small arbors. Many don't. It'll cut cleaner as a saw on a 1/2" or 3/4" arbor, but it'll be cheaper as a woodruff.
Anybody have an opinion?
In reading all the various 1911 sites, I've seen all sorts of different frankenstein tricks for getting around the barrel bed being a freak size, and some of the other drills being downright weird or custom. Nevermind all the weird ways they do the slide cuts. (A dremel with stacked abrasive disks? Seriously??)
Do you think it would be viable to offer a way out of the wilderness? The problem is that the goal here is to keep my cutter guy's lights on. Which means that they won't be 'dirt cheap'. I'd expect the big mill to be about $50, with the other drill & reamer sets being in the $15 range. Don't know yet about the woodruffs or the slide saw, but I'd expect at least $25 ea.
So, what's the collective read on whether or not this is a good idea?
Brian
Brian
