caprio
- Jan 24, 2013
- Discovery Bay, CA
AR-15 80% Lower Milling - Mill Recomendations
I have an 80% lower and need to complete it. I've seen a few video where guys complete
these with only a drill press. Seems a bit crude.
I'd like to know if one of the smaller milling machines like the ShopFox
or Harbor freight milling machines would be adequate for the job?
ShopFox M1036 Features ~$400
Motor: 0.2 HP, 2A, 110 Volt, single-phase
Drilling capacity: 1/4-Inch
Spindle taper: JT1
Spindle travel: 1-1/2-Inch
Table size: 3-1/2-Inch by 8-Inch
Harbor Freight Mini Mill 2 speed variable ~$500
Horsepower (hp) 4/5
Maximum speed (rpm) 2500
Minimum Speed (RPM) 1100
Number of speeds Variable
Spindle Taper R8
Voltage (volts) 120
Chuck size (in.) 7/64 in. - 1/2 in.
Spindle taper: JT1
Horsepower (hp) 4/5
Spindle Taper R8
Voltage (volts) 120
