Hi
First post here.
I have a winchester 1890 octagon barrel that needs relining. I have drilled it out and realize there is a fair gap between the barrel and the liner wich if left alone will look terrible on the muzzle end.
This is a flat muzzle no counter bore to hide anything and no bluing on the end.
I have taken a few one inch long slices of an old liner and glued them in 5/16 hex nuts, they represent about the same size hole and the same hex barrel end.
I read somewhere to peen in the end to close the gap, that was a disaster.
I have silver soldered several of them but could not keep the solder from flowing over the edge of the nut, if that was the barrel it would require a re blue wich I am trying to avoid.
So basically I am looking for ideas on how to fill this gap and have it look good, without re blueing the barrel.
Thanks for any suggestions, Tom
First post here.
