AR15 gas port hole location
Results 1 to 10 of 10
    Oct 2008
    Stillwater Ok
    20
    Default AR15 gas port hole location
    Ok I am building a 6x45 and plan on using the rifle gas tube but how do I know where to drill the hole. I have the barrel on the lathe and turning it down but need to know how far the gas block and port is from the chamber end.
    Mark
    Apr 2008
    Northern VA
    318
    Go to Biggerhammer.net. There are AR15 blueprints there. You should be able to get the info from the blueprints.
    Apr 2007
    N. MN
    153
    On barrels with the rifle-length gas-system, I make the shoulder for the gas-block 12.125" from the shoulder that the barrel-extension screws up to.
    Hope that is what you were looking for.
    Jan 2006
    437
    35
    The NRA AR-15 book shows the port to be 12.420" forward of the barrel shoulder that stops the barrel extension.
    RWO
    Mar 2006
    New Jersey
    900
    10
    201
    Try to center the gas port hole in a groove. You will have better accuracy and less problems with fouling in the port.
    Oct 2008
    Stillwater Ok
    20
    Ok great thanks for the help. I got the barrel turned down to 1in and threaded for the extension. Now I am going to finish turning it to the .937 for the gas block and then order the reamer.
    Apr 2007
    N. MN
    153
    I like going about it the other way around. If you profile and thread the barrel first, you are on the hook to make the chamber perfect the first time. I rough the chamber, then finish it. After close inspection, I cut the blank to about 1/4" longer than the desired barrel length. Then I put the barrel between centers and thread it. After I install the barrel-extension, I proof-test the barrel with one shot. You can inspect the brass carefully for any problems in the chamber, and borescope the throat and bore for any problems as well.
    If it passes those "tests" then I profile the barrel, and eventually drill and ream the gas-port. Once you profile it, or drill the gas-port, you are pretty well stuck with what you have. If you end up with a problem in the chamber, and catch it prior to profiling, you can cut the shank off and start over.
    With all due respect to MilGunsmith, I have never made any attempt to time the gas-port into a groove. Before I started chambering my own barrels, I took the advise of one of the most respected AR smiths in the country. He doesn't "time" the gas-port to the groove, so I never did either. I drill and ream the port when everything else is done, and have never had any adverse results from where the port ends up. Take care in drilling, reaming and removing any small burr that may remain, and you will be in fine shape.
    Oct 2008
    Stillwater Ok
    20
    Well now you tell me!! Just joking. I did profile it to 1" and then to .938 for the gas block. I guess if I mess up I can still set it back and use .750 gas block. This is my first time so I am learning the hard way, but so far so good. I have a jet 13x40 lathe and so far it is doing good job. Thanks I again for all the help.
    Apr 2007
    N. MN
    153
    You didn't "mess up". I was only telling you how I do it, and why. I spent most of my life in medical and industrial electronics. Many operations I would have to preform could cause tens of thousands of dollars worth of damage if done incorrectly. It just changes the way you think, and proceed through a procedure. Most of the time it isn't necessary, but once in a while it will save you a pile of work, or a scrap barrel.
    Make sure you have any small burrs taken care of before you fire it. There are many ways to do it, but if you drill the port one number size smaller than the desired port, then ream it to size, any burr left will be very small. I use a VERY tight fitting bore brush to break off any remaining burr.
    Sep 2007
    okc okla
    85
    Thumbs up AR gas port location
    it depends on barrel lenght,16" have it 4-6" from muzzle,as do 20".the M4 carbines the military has are problamatic,as to reliability,thier GP location is 2-3" from muzzle,its too close,as gas preasure dosent have enough time to properly cycle weapon.M1 rifle has this prob,and ammo must be precisely loaded f proper funtioning,not just any 30-06 ammo will work in m1 rifle.keep your GP location at least 6" from muzzle.
