gzig5
Hot Rolled
- May 10, 2005
- Milwaukee, WI
I need to attach a spider to the LH end of the spindle on my EMCO Super 11 for dialing in barrels through the headstock. The spindle has a section about two inches long on that end that appears to be ground and uniform. I don't want to mess with removing the preload nut and threading it on so I need to affix it to the smooth portion. What would be the best way to go about this? I've got a hunk of 8620 that would give me a wall thickness of about 3/8" over the spindle. I've considered using two sets of three or four set screws an inch and half apart with brass or copper tips to connect it, or possibly splitting it lengthwise once or twice and installing clamp bolts or a split clamping collar. Obviously a near slip fit to begin with is desirable for either method. Am I overthinking this like I usually do or is there a significant benefit to either way, or something I haven't considered? There is a slot in the end of the spindle probably for the lever collet closer I don't have that a pin/bolt could go into to drive the spider. I've found some pics online but it seemed that all of them were threaded onto the end of the spindle.
