Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Like Tree6Likes
Thread: Barrel Extensions
    Feb 2011
    Edmonton, Alberta, Canada
    1,687
    Default Barrel Extensions
    I just started another barrel job and noticed that my written notes are getting to greasy to read so I decided to start using the computer for something practical. As if video games, porn, music and movies are impractical! I’ll start dropping these drawings here as ambition allows it. Would appreciate it if others did the same. Especially on the newer stuff. It helps to have a rough drawing to look at when quoting jobs. I have been caught several times over the years having to cut a freak metric thread or a complicated extension after I had quoted for a simple job.
    This is a drawing for the new Sako 85
    Grizzlypeg likes this.
    Feb 2011
    1,687
    Drawing for the 700 Remington
    Feb 2011
    1,687
    Drawing for the Swedish Mauser
    Attached Thumbnails Attached Thumbnails rod-henrickson-small-ring-mausers.jpg
    Feb 2011
    1,687
    Drawing for the HS Precision 2000 Short Action
    Attached Thumbnails Attached Thumbnails rod-henrickson-hs-precision-2000.jpg
    BobbyBailey is offline Aluminum
    Nov 2010
    upper southwest Arkansas,USA
    93
    Thanks for posting those.
    Bobby
    Fitch Williams is offline Aluminum
    Oct 2004
    PA
    108
    +1
    Fitch
    Feb 2011
    1,687
    Drawing for 98 Mauser
    Feb 2011
    1,687
    Drawing for the Savage 110 series
    Attached Thumbnails Attached Thumbnails rod-henrickson-savage-110-series.jpg
    Johnny V is online now Cast Iron
    Jan 2005
    Mentor, Ohio
    251
    Hi Guys,
    Thought this might be of some interest from the Home Gunsmithing forum. A pdf file with 29 pages of barrel shank dimensions
    Later
    Johnny V
    NRA Life Member 1976
    Feb 2011
    1,687
    AH HA Thanks. Much like my old notes minus the rips and the grease !!!!!!!!!!!
    ⎝ᄽ⏝ᄿ⎠
  11. #11
    Jan 2005
    Mentor, Ohio
    251
    speerchucker30x3,
    I know the rips and grease all too well, but keep up the good work with your extension drawings along with the brief history - great reference material....
    Maybe the moderator(s) could sticky this thread???
    Later
    Johnny V
  12. #12
    Quick Karl is offline Cast Iron
    Jul 2011
    Scottsdale AZ USA
    378
    I think you might want to check Page 2 of your PDF Large Ring Mauser 98 - I am sure the thread length is a typo.
    Quote Originally Posted by Johnny V View Post
    Hi Guys,
    Later
    Johnny V
  13. #13
    Feb 2011
    1,687
    Quote Originally Posted by Quick Karl View Post
    LOL His old notes are as bad as my 30 year old notes Karl I think the top just wore off the 6 in .625 inch. That's why I'm redoing all of mine right now. I look at some of em and all I can think is W. T. F. !?!?!?!?
  14. #14
    Jan 2005
    Mentor, Ohio
    251
    Hi speerchucker30x3,
    I'm getting an "Invalid Attachment" message when trying to open the BSA Martini Cadet drawing.....
    Johnny V
    NRA Life Member
  15. #15
    Feb 2011
    1,687
    Johnny V
    NRA Life Member
    I'm trying to fix it this site does not support outsized JPGs. I will upload the drawing and text separately in a minute
  16. #16
    Feb 2011
    1,687
    OK I had to do some scronching and squitching to make all this work and I will post the text separately here. The forum software reforms the JPGs and makes them to small to read. Sorry, not me it's the software saving storage space.
    BSA Martini Cadet *** 14 TPI 60 degree V thread. The Martini can be a real pain in the ass to barrel if certain steps are not followed. The barrel extension and threads must first be cut and threads must be to a class 4 fit. The .650 inch ring on the face is important as it will later be used to find center. It does not have to be .650 but a ring should be there.
    After figure A is complete the barrel must be screwed on to the receiver tightly with an action wrench and the threads worked several times to remove all crush otherwise the barrel will screw over center when you are taking it on and off to final fit the extractor. YOU WILL FORGET THIS STEP ONCE IN YOUR LIFE! Witness mark the barrel and receiver at this point. With the barrel in a vise level the receiver and then clamp a machinist clamp on the barrel and level the clamp to the side of the receiver. This will allow you to level the barrel to make the extractor cut.
    .Proceed to figure B and level and square the barrel in the mill vice and slab off to establish the 90 degree cut for the top of the extractor. This cut is approximately .020 inch below center. I use a woodruff key cutter but the barrel can be inverted and the cut made with an endmill.
    Finally, figure C, reposition and level the barrel in the vise to 12 degrees and slab off the rest of the extractor cut with a woodruff cutter or endmill.
    Screw the barrel back on to the receiver and check for extractor fit with layout fluid and file if necessary. File the barrel, NOT THE EXTRACTOR! You can set the barrel back if you screw up but finding a new extractor is next to impossible and they are a bitch to make. You will make that mistake JUST ONCE in your life as well.
    Cut the chamber by hand with a SMALL T handle. Do not bother to try to cut the chamber and extractor at the same time by clamping the two together. The extractors can be quite tough and can destroy the reamer, or push the reamer up and create an egg shaped chamber. Final fit the extractor to the chamber with a soft stone or what ever you are comfortable with.
    These measurements are approximate and only actual measurements taken from the action to be barreled should ever be used. No two Martinis are alike.
    Attached Thumbnails Attached Thumbnails rod-henrickson-bsa-martini-cadet.jpg
  17. #17
    willbird is offline Banned
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    Quote Originally Posted by speerchucker30x3 View Post
    I'm really into this one. I have a 310 martini that my dad fit a section of a 1903a3 barrel to and he chambered it to 32 S&W long with a chucking reamer. I have a length of Pacnor 1/8 twist 30 caliber barrel and have considered having Dake Kiff make a reamer for 327 federal with a .308 throat. I also have a "Snap" extractor with the full instructions but all in all I think single shots should use rimmed ctg. I also considered a rimmed 300 blackout made from 357 maximum brass...but there is little gain there over the 327 federal I bet. The 1/8 twist would be for subsonic use with a supressor.
  18. #18
    Feb 2011
    1,687
    Drawing for the Browning A Bolt.
  19. #19
    gorrilla is offline Stainless
    May 2007
    Central Texas, West and North of Austin
    1,042
    You say that like it's something out of the ordinary? Nearly every time I pick up some old reference material that I've notated, that same acronym comes to mind. "WTF?"
  20. #20
    Feb 2011
    1,687
    Another barrel installation, another new drawing. This one is for the Thompson Center Icon.
