hepburnman
- Feb 20, 2013
- NJ
I'm working up to chambering a barrel through the spindle and I'd like to ask what is the best way to chuck an octagon-shaped barrel in a 4-jaw chuck so that it can pivot without bending when the spider at the muzzel-end is adjusted? I am planning right now to use a ring of heavy copper wire between the barrel and the jaws of a 4-jaw chuck. Some others here use a split-ring of aluminum but this is usually used on/made for round barrels. I'd like to know if the ring of copper wire will be as good as the split-ring method for an octagon barrel? [the theory is that you want to not grip the barrel at the breech-end so rigidly that the barrel bends, rather than pivots, when you adjust the spider at the muzzle-end when you indicate and center a short-length of the throat-area of the bore to run concentric with the spindle. Also, this copper-ring/pivot-point on the barrel should be in-line with the forward-most throat-area in the bore that you are indicating (with a long-point DTI) so that this concentric "circle" does not shift position when the spider is adjusted - sorry if this is old-hash for everyone!].
