Assuming a properly chambered barrel, a blueprinted action (lug faces, threads, receiver face) and a trued bolt (bolt face, bolt nose, lugs), how much affect is the slop in the bolt tolerance on accuracy? We're building a rifle that we'd like to be sub MOA if possible. I measure the bolt body to be 0.696". I haven't mic'd the action yet, but for the sake of the question we'll assume 0.700. If the lug faces on both bolt and action are trued properly, how much will the bolt slop affect things? Is sleeving a factory bolt worth it, and what are the downsides - Im assuming that the tolerance helps when the rifle faces "bush conditions" (grime and dirt, temperature fluctuation, etc.)
