brass cannon
Results 1 to 16 of 16
Thread: brass cannon
    Apr 2009
    Kewaunee wi usa
    68
    Default brass cannon
    Hi Guys
    A guy at work wants me to make him a brass cannon, black powder
    1 1/2 inch across the flats of a bar of hex free machining brass
    I'm concerned about wall thickness...............
    kinda important.............any suggestions.............Mikey
    Sep 2004
    NH
    1,042
    60
    I wouldn't make it any larger than .50" bore and leave the same for wall thickness. You might be able to go larger but why risk it? How will the trunnions be attached?
    Jun 2010
    Missouri
    362
    8
    If your friend wants to shoot paper wads and use the gun for a noise maker, the dimensions above would work pretty well. If he wants to shoot projectiles, I don't believe I would use brass.
    If anyone here decides to attempt to size the barrel for you, they must use the thick wall pressure vessel equations. The more simple thin wall equation, [stress]=[Pressure][outer radius]/[wall thickness], is flat out incorrect for this problem.
    Identifying the specific alloy is also important to get a sensible answer.
    [Work like this is my technical specialty.]
    Apr 2009
    Kewaunee wi usa
    68
    Default brass cannon maybe not
    guys thanks for the quick replys
    i always worry about someone who plays with gun powder
    with no experence.........I might rethink this project
    Thanks again ........Mikey
    Aug 2004
    OK, USA
    1,441
    5
    146
    Wise to reconsider if its a shooter.
    With a free machining alloy there is a good chance the tensile strength in the hoop is much lower than the tensile strength in the axial direction.
    Jul 2004
    Houston, TX USA
    27,459
    In your reconsideration you could reference the 1862 Ordnance Manual which clearly gives the constituents of the "yellow" metal used for ordnance. This was a tough bronze containing 90% Copper and 10 % Tin - hardly anything like brass.
    John Oder
    Feb 2004
    peekskill, NY
    23,727
    3905
    "The more simple thin wall equation, ... is flat out incorrect for this problem."
    Only solution then, is to thin out the wall!
    Jul 2004
    Vicksburg, MS
    4,938
    30
    255
    Build the cannon any way he wants but DO NOT drill the hole for the fuse. Let him do that, which can be done easily with a proper sized bit and a hand dill. That way, you didn't make a cannon, you made a model, your customer turned it into a cannon.
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    926
    Quote Originally Posted by occifer19 View Post
    Hi Guys
    I'm concerned about the ATF....and your insurance policy.
    Are all your assets in your wife's name?
    Jun 2010
    Missouri
    362
    8
    Quote Originally Posted by jim rozen View Post
    Funny.
    I would have no problem making a brass barrel cannon for my own use as it would always be under my control, too.
    Historically, brass barrel rifles and pistols from the flint era are not unknown, but I wouldn't say they are terribly common, either. Cast bronze cannons are common. But, there was a better way.
    Olin has a nice brochure available that discusses the uses and properties of Alloy 260 cartridge brass (much more than cartridge cases), including mechanical properties for different conditions of work hardening. A search for "Olin alloy 260" will turn up a link, or: Olin Brass Corporation will get you there.
    Kansas Cannon Works makes some very nice small cannons from steel bar stock that I think are a good value.
    Kansas Cannon Works Cannon Page One
    I have a one inch bore Napoleon. Wish I had a golf ball barrel since projectiles are cheaper.
  11. #11
    Apr 2009
    Kewaunee wi usa
    68
    Default brass cannon not
    Guys
    Thanks for the input, I told him about your input, he said he wants a noise maker
    I don't think I need the grief from someone that thinks it is a toy
    less and less interested in this thing.
    Thanks Mikey
  12. #12
    Oct 2006
    williamsburg va
    7,886
    839
    1714
    Sooner or later someone WILL try shooting projectiles out of it. I am reminded of the story about a Scout Master who used something like 2 pounds of black powder in a smallish cannon for firing salutes with his troop standing around. Could have blown up!!
  13. #13
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    Do be careful out there.
  14. #14
    Jun 2010
    Missouri
    362
    8
    The problem goes beyond over charges of black powder.
    Non-shooters don't know the difference - a pile of smokeless powder is black, and a pile of black powder is black. Many shooters don't know the difference, either.
    The first owner of the cannon might be knowledgable. What about the next owner? Last week end I found a neat cannon on a field carriage at a garage sale, complete with touch hole and stories from the original owner's children that it was shot. Thing is, there is something that is not right about the barrel on that gun, it's not carbon steel, I'm over 90% certain it's a stainless material - it has scattered rust along with clear patches free of rust, and near as I could tell it has been stored in the garage without climate control. I passed, although the price was right for the carriage alone. The point is, I don't know the cannon's background without doubt, so the risk is beyond my range of tolerance.
    The photo above is one consequence. The KA frat at the University of Missouri - Rolla killed a student with a cannon blow up about 1978. That's not the only example, either.
  15. #15
    Jul 2005
    2,610
    70
    222
    If I wanted a noisemaker, I'd be temped to get a piece of barrel blank from Gun Parts Corp and go from there.
    These are nice. Check the video link.
    http://www.cannonthunder.com/services.html
  16. #16
    Feb 2001
    Arizona
    2,063
    260
    Default Noise Maker
    Probably the best thing for a noise maker is a thunder mug. These are thick walled short muzzle loading devices that are fired vertically. For example, 3" diameter, 1" bore, 12" overall length, 10" bore length. They usually have a handle for easy carrying. And they are not readily converted to launching projectiles.
    Here is a video: thunder mug video
