garrettec2011
- Jan 3, 2012
- Centerville Ia
This post is not about gunsmithing but reloading. I simply did not feel like creating a new account on another site when I am sure I'm not the only person that reloads on this one.
I recently gotten into long range shooting and I will admit that I am now addicted. So I order 1000 .308 new casing to be reloaded for my first time. After shooting around 200 rounds I decided I would play around with once fired casing. I first threw them in an overall length gauge that my old man has and they were short by 10 or 15 thou. I figured it would fix it by running it through the dies to reform the casing but it did not gauge after running and it seemed like I should not have been putting that much pressure on the press to cycle it.
I have two questions on this post. The first being should there be a force applied to the press to the point to were you become worried about ceasing the casing in the die or breaking a part on the press? I have loaded all these rounds using standard so I didn't just pull them out of my a**. I also comparied the velocity to powder charge and my rifle only shot 50 fps higher.
My second question. Have noticed that after 30 or so rounds without cleaning that my accuracy drops from shooting 6 inch groups to maybe I'll hit the target and maybe I won't. While cleaning I see brass shaving on the cleaning pad. Its obvious where its coming from but why am I getting these shavings if I'm very close to a standard charge? I will add that as a machinist I noticed a burr on the OD of the mouth and would get rid of it so I chamfered the both OD and ID of the mouth with an RCBS deburring station.
