brownells lathe centering bar
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Dec 2010
    DFW, TX
    7
    Default brownells lathe centering bar
    Anyone have experience with one of these.
    LATHE CENTERING BAR - Brownells
    Dec 2008
    Vt USA
    6,010
    531
    1841
    Default No, If I question the tail stock alignment I can dial it in
    Quote Originally Posted by jroberts1968 View Post
    Or take a couple of cuts on a length of bar out of the scrap box.
    But if you are into shiny "tools" (tooling bars even) go for it. I think it's a bit spendy for my needs
    Oct 2009
    BC Canada
    1,227
    151
    587
    you MUCH need more practice on your lathe if you think you need that.
    Feb 2011
    Edmonton, Alberta, Canada
    2,113
    10
    554
    Well its 8 inches of ground 1 inch material that's been faced and center drilled at each end. I can see $84.21 there. Some where. I guess. But I think you could make one for $10.00 if you have a center drill, lathe and a place that sells ground stock.
    This sort of does the same thing and Fisher edge / center finders are only $12.00.
    Chamber reaming between centres
    Just saying.
    Nov 2004
    RC, CA
    1,899
    210
    348
    Sure, but that only tells you if your tailstock is aligned when it's up close to the headstock. This bar tells you it's aligned when your centers are exactly 8" apart. And that must be important or else they wouldn't be selling these, right?
    Oct 2009
    BC Canada
    1,227
    151
    587
    if your tailstocks not aligned at different distances your lathe is likely not properly levelled. Screwing with the tailstock will not help you here.
    They're are people out to screw you for every dime you have, especially with the new craze crop of basement machinists. Some of the tools out there serve no purpose other then to seperate man from his dollar.
    Dec 2010
    Pa. usa.
    98
    I got sucked in on one, if you want to buy cheap i'll sell it. I ran the mic over it and it's not even round........junk.....jim
    Feb 2011
    2,113
    10
    554
    I was lucky. The first time I needed to re-center a tailstock, the guy I was working for told me that the book way to do it was to clamp a CoAxial indicator in the chuck and run it on the inside of the tailstock spindle. Then he told me to get an edge finder out of the tool crib and clamp one end in the chuck and the other end into the Jacobs chuck in the tailstock and measure the split, center it up, and stop costing him money by wasting time. The only man that I ever met that was grumpier than myself.
    Oct 2009
    Parrish, Florida, USA
    450
    57
    Quote Originally Posted by speerchucker30x3 View Post
    Is that possible? Just sayin', er askin'
    Jun 2012
    Land O Lakes, Ontario Canada
    36
    Alright I confess. I use a shopmade version of the same that is 24" long made from 1" centerless ground. I find it a really fast and easy way to give everything a quick check just before I mount a barrel.
    And I don't care if I'm not the coolest kid in school
  11. #11
    Feb 2011
    2,113
    10
    554
    I was always taught that using an indicator on the apron and a pre-turned bar would not give an accurate reading in some cases. On most lathes the tailstock and the apron run on separate ways. As a rule the ways of the apron wear more than the ways of the tailstock. The ways on the tailstock actually wear very little as its seldom moved back and forth. The only truly accurate way to align the headstock and tailstock is to run a CoAxial indicator in the chuck with the indicator needle on the inside of the tailstock quill or to run 2 precision ground pieces of stock together, one in the headstock and one in the tail stock and measure across the split of the two parts. This eliminates any drift of the apron as you move it up and down the bed. Theoretically, the CoAxial indicator is the most accurate as the quill and the chuck used to hold the precision ground stock invariably add error to the system. However, its been my experience that worrying about such trivialities gives people ulcers and makes them goofy so I try not to give it much thought. But I do have a CoAxial indicator. Somewhere. LOL
  12. #12
    Jun 2012
    36
    I agree the tailstock and the carriage are on different ways, but that almost seems to be more of an argument in favor. Ultimately the toolbit is going to be in the same position as the indicator so what counts most is the carriage running parallel to the centerline.
    I guess the one caveat here is I only use the bar between centers not when using a chuck
  13. #13
    Feb 2011
    2,113
    10
    554
    That's the whole problem. The carriage/indicator and the center line are on different planes. Whether you use a center or a chuck makes no difference. You can't use a bent path to check to see if the path next to it is straight. It can not be done. If you try the bent path will always be getting closer or father away from the straight path as you walk along it. The reality is that you can't even tell which path is bent. You simply have to assume that both paths started out as straight and the one with the most abuse is the bent one. But I don't think a thousandth or two makes a big difference in the big scheme of things. Besides even with more and possibly better micrometers than a lot of good machinists that I know have, I can't measure and cut much closer than + or - .001 inch and neither can my competition, despite their claims.
  14. #14
    Feb 2001
    Arizona
    2,063
    260
    I can cut to .001" but the problem is doing it every time. :-)
  15. #15
    Feb 2011
    2,113
    10
    554
    AH HA. A funnyman. My cuts always come within one tenth of one thousandths of an inch. The numbers to the left of that last number can however, be slightly erratic. he he
  16. #16
    May 2007
    Central Texas, West and North of Austin
    1,628
    178
    523
    I've always used a dial indicator. Mag base, stuck to the chuck. Swing it around the live(or dead) center, adjust the tailstock body to true. Need to check it out further. Clamp a fairly stiff bar in the chuck. Whether it's perfectly true or not is of no consequence, long as it's rigid and stable in any eccentricity it has. Stuck it out to the desired location, fasten the indicator to the bar, swing it in. Now, if it shows different numbers than it did up close, you likely have a leveling problem. Or the beds twisted. Or worn funny, up close likely. But that would be one worn out lathe. Get past all that, check your part for runout in the chuck, and Bob's your Uncle.
    Good dial indicator will tell you as much as the gadget. Gadget is for making it easier and quicker. But tells you nothing about the level, twist, or wear in your lathe. I've made something similar out of PGS(Precision Ground Shafting) mounted in a set of collets, centerdrilled(carefully), and pointed on one end to fit in a centerpunched mark. For centering odd shaped pieces up in a four jaw. Still have to have the tailstock centered up well. Probably wasn't accurate to the tenth, but accurate enough for the molds we were doing.
  17. #17
    Feb 2011
    2,113
    10
    554
    I make sure the machine is level, but I don't go beyond zeroing at the chuck with an edge finder, which is as accurate as the micrometer you measure the split with. I suppose one could over think and over check everything but I can't do anything about bed wear or warp so its pointless to worry about it. If it gets to the point where these things are an issue I would just buy a new machine. But I have never have had to do that yet and I don't expect I ever will. Admittedly, it took a while to figure it out for myself and except it, but as I was taught, anything beyond holding an edge finder in the tailstock and headstock is just an excuse to waste time. On top of that everyone that has a mill has an edge finder and if they don't they are only $14.00 for a top of the line model and about $7.00 for a Chinese knockoff. Setup time is as quick as you can run the tailstock down and clamp it in both chucks. Occam's razor always applies.
  18. #18
    Jan 2005
    Toledo, OH
    1,016
    29
    The only problem with using an edge finder in that manner is that it assumes the chucks are zero-zero. They will not be, particularly the lathe chuck if it is a three jaw.
    I do agree with not overthinking the alignment, you will endup chasing your tail. If it is critical, I take a light cut, check for taper and adjust the tailstock as needed.
  19. #19
    Mar 2012
    Virginia, USA
    123
    18
    14
    Tubalcain has a good Youtube video on making an inexpensive alignment bar that you an make for the exact length you want your work piece to be.
    MACHINE SHOP TIPS #78 Aligning Lathe Centers pt 1 of 2 tubalcain - YouTube
  20. #20
    Feb 2011
    2,113
    10
    554
    Quote Originally Posted by precision tools View Post
    After you have both ends of the edge finder chucked up turn the chuck until you see and feel the high point on top. Then measure the split on the sides. If your scroll chuck runs out more than .003 inch you might want to knock it back in. Loosen the back plate so that the bolts are so/so snug, put a piece of precision ground stock in the chuck an run an indicator on it. Use a piece of babbit or a lead hammer to true it up and re-tighten the bolts.
