Hi Guys,
Hey there Mr. G,
I haven't been around in a while, Looks as if I've got some reading to do!
First a little note, for all the Black Rifle builders out there, I just finished a rifle using a High Standard receiver. If they all come like this one, Man! Simply Gorgeous! I didn't even have to ream phosphate out of the holes! I did absolutely NOTHING to this receiver! I don't know about you, but it's been a while since I've been able to say that!
Now for my question, and yes, I performed the sacred search, got 4 hits, and only one of them was useful.
Does anyone have a set of plans, a detailed sketch, or even just a sketch, on Milling An Aluminum Receiver Block? It seems as I get older I'm reverting to Kindergarten, I need pictures.
I have a Donor gun and I want to document the things I change as I go.
I have a Savage 112V Series J, in 25-06 and a 4 X 9 Leupy on it. It has been a jackhandle since the day I bought it. The scope is fine on other guns.
I Acraglassed it, free floating the barrel, that helped some. I worked over that nasty trigger, it's not bad now, no change in accuracy but an improvement in comfort. I'm considering an Accu-Trigger.
I re-crowned it, bigger help but still not good. The action should be more than rigid enough as it is single feed {No Magazine of any type}. And I have a new 30-06 barrel on stand-by to screw in at the end, unless miracles happen. And also a thicker recoil lug on order.
If you are not a great artist, like me, I'd be just as Pleased to get your info by PM. I should still be listed but just in case [email protected]
TIA for any assistance.
Take Care and Be Well,
Ken
Hey there Mr. G,
Ken
