cgmaster
Cast Iron
- Jun 9, 2008
- Ocean Springs, MS
My new lathe is longer through the headstock (about 32") so I am chambering between centers. I don't know if anyone has tried this but here is my plan.
The spider I made on my lathe I turned the id and od.
1. center drill muzzle with piloted reamer and turn od for 3/4" or so concentric with bore.
2. With spider mounted in lathe as if I was doing a receiver install the barrel in it with the chamber end out enough to cut tennon. Place steady rest on spider. Center the barrel using Gordy range rod.
3. Release the spider from the 4 jaw. slide the steady rest with the spider and barrel down so that I can clamp the muzzle end up in the 4 jaw with copper wire holding it
4. Indicate again with rod in chamber end adjusting only the 4 jaw holding the muzzle. Mark high spot on muzzle. Do not adjust spider jacking bolts as they should be set from when it was mounted in the 4 jaw. Note the muzzle may not be centered so there would not be any stress on the barrel.
5. Cut tennon and chamber.
In theory this should get the throat, chamber and tennon all aligned. When this is done flip the whole thing around to do the muzzle the same way (crown and/or thread)
The problems I see.
1. I don't know how to set up my flush system this way. I thought about tapping the end of the barrel and running a pipe to the outside of my headstock where I can attach the flushing bearing.
2. Time consuming and a complicated.
Another option I am considering is creating a long spider with heavy wall pipe and support it on the end in the steady rest
1. I can then create jacking bolts every few inches to support any length barrel.
2. I would not have a way to indicate the muzzle end in this setup to find the high spot.
I really would prefer to be able to use through the barrel flushing with my carbide reamers. Any ideas are greatly appreciated. Thanks in advance.
The problems I see.
