kd1yt
Cast Iron
- Dec 6, 2013
- Vermont, USA
I've spent much of the last couple of years moving and reviving some machine tools that I was fortunate to be in the right place/right time to receive 'free if you move them' (though they were in locations where that was no small doing- the Cinci Toolmaster mill was in a basement).
My lathe from this endeavor is a nice (once I removed decades of filth) early 20th century flatbelt/cone pulley Leblond 14" with nice long bed, without much obvious wear, and with a nice complete set of steady rest, follow rest, taper attachment, and 3 and 4 jaw chucks. However, the cone pulley means a very, very long spindle/ headstock (well over 2ft total from chuck end to far left side...)
One of my interests in pursuing all of this is to be able to learn to do some DIY smithing, including barrel work.
The diameter of the bore of the lathe spindle is about 1.25. The length of the spindle nixes the option of using a 'spider' at the left end of the spindle bore to center a barrel to do things like chambering through the headstock. But this is the machine that I have, and the only machine that I am likely to have for a long time, maybe ever, at least as best I can see unless I once again find myself in a "right place right time" that I am not going to count on happening
What I am wondering is whether a careful shimming of the barrel at the muzzle end within the spindle could achieve something decently approximating the effect of a "spider"-
-say if the barrel's end opposite the chamber end were wrapped in something like 'painters tape' until it became a firm friction fit within the spindle? I realize that there is some imprecision in that makeshift approach- but on the other hand, the length of the spindle would allow that "support shimming" at the far muzzle end of the barrel furthest from the chamber area, which would [seemingly] reduce angle/error compared to support in a spider near barrel midpoint....
Am I on to something that could sort of function to make the best of an otherwise limiting condition, or am I best off planning to learn to do any chambering or similar work in some way other than "through the headstock?"
Thanks in advance for the patience with this newb-ish question; I greatly appreciate all that I have learned and continue to learn here on PM
