Removing and Replacing Browning A Bolt barrel
  • Thread starter Rustystud
  • Start date
  • Replies 3
  • Views 11,847
R
Rustystud
Guest
Normally I don’t do things that I know that later down the road I may regret. I have a very good friend whose son has a Browning A bolt in 300 Win Mag. The son is small in stature and his father wants me to install a muzzle brake on his son’s stainless Browning A bolt.
I have been told that Browning A bolt rifles are made from extruded metal and not milled from a piece of billet metal. I have been told horror stories about these actions cracking and crumbling when someone tried to remove or replace the barrel. I have further been told that the barrels are put on with a glue instead of grease an/or anti-seize. I have been told they frequently seize up during the barrel removal process. I have been told that within the last few years that browning changed the threads on their A bolts from 20tpi to 32 tpi. This would significantly increase the surface tension greatly increasing the odds of a galling with stainless steel to stainless steel interface.
I contacted Browning’s service center in Missouri and they refused to provide me with any information saying that it is proprietary. There web site list approximately 25 independent gunsmiths are factory authorized Browning service centers. I called about a half dozen of them and asked if they removed any Browning A bolt barrels to install muzzle brakes and or replace the barrels. None said they had ever removed a Browning A bolt barrels. None stated they had removed any A bolt barrels from the action. Some indicated they had heard some of the same previously discussed comments about Browning A bolts. Some went as far as saying if one is buying a new rifle they should not buy a Browning. One stated he formerly worked for Browning in the Missouri service center. He stated that Browning only paid $85.00 for a barreled action and when one was returned to the service center that required it be re-barreled, the action was destroyed and replaced with a new barreled action.
I thought about making a mandrel to fit inside the action and an a collar for the barrel. Turning and threading the muzzle in the steady rest, (Without removing the action from the barrel). This goes against my better judgment. Brownell’s sells a Browning A bolt wrench head for their action wrench set for about $80.00. They too could not give me any advice on removing Browning A bolt barrels. I am of the mind to tell my friend that I cannot install the muzzle brake on a Browning A Bolt.
I believe John Mosses Browning would roll over in his grave if he knew the company that bares his name is making and selling products that cannot be serviced by a machinist/gunsmith.
If you have any experience or advice about removing and replacing Browning A bolt barrels I would appreciate hearing it. Especially if it was a later model Browning A bolt.
Nat Lambeth
[email protected]
I have never removed a barrel from an a-bolt, but I have one. I thought that all of them came with a threaded end since they had the BOSS system.
Nat: Can't you just put the barrel through the headstock and let the action turn on the left side of the headstock? At threading speeds being out of balance does not matter.Gary P. Hansen
Browning R&D Contacted
I talked with a Browning Engineer in their R&D Department. Very nice man, he appologized for the response I got from their Service Center.
He said with the right wrenches and technique that a Browning barrel will screw off just like a Remington. He confirmed 32tpi, Anti seize and no glue.
Nat Lambeth
