Forcing cone answer!
Well, necessity being the mother... and all that, I found the answer to my question about the forcing cone degree of chamfer. No wonder no one responded, it's a fair long treatise in Brownells instructions for the tool... but it did get a number of looks, so there's a bit of curiosity. At any rate, here's the link to the pdf on the Brownells website;
http://www.brownells.com/aspx/NS/GunTech/Instructions.aspx?p=26157&t=2&i=413
Here's the short version copy/pasted from the pdf;
The Chamfering Cutter (“D”, Fig. 1) is threaded onto the Extension
Rod after the appropriate Brass Pilot is in place. Three Chamfering Cutters
are provided: an 18° Cutter for 9mm to .41 caliber barrels; an 18° Cutter
for .44 caliber to .45 caliber barrels; an 11° Cutter covering all calibers from
9mm to .45. Also available is a 5° Cutter for .38/.357 which duplicates the
Ruger factory chamfer for these calibers. The 18° chamfer has been used
quite often by firearms manufacturers, and in most instances, will provide
a slight accuracy advantage when shooting jacketed bullets. The 11° Cutter
was designed by Ron Power after extensive research and experimentation
during which Ron found that the 11° chamfer provided optimum accuracy
when using hollow-base lead wadcutter bullets, the type most often used
in PPC guns.
Regards,
Kevin
