One has to exercise a little good judgement which many do not these days and look at price only. Machine choice depends on what range of jobs are expected and the desired tolerances vs your skill level. It won't chew through deep cuts like heavier machines and it was never intended for production work. But as for my needs, I would not have been served any better over the years by a $5,000 - $12,000 lathe. So, why would I spend several thousand more for no reason...I wouldn't and didn't. I don't over tool it and I use 12L14, brass, aluminum and bronze for most work, take light cuts and use the $12- $15 per part I produce every 5 minutes for other hobbies...usually collectable firearms. If you have no inclination or patience to set up the machine properly, including adjusting all gibs, adjusting spindle bearing preload, correcting any headstock taper( mine had .001" per 8") and leveling properly, you will likely be a "chattering piece of crap" seller quickly.
