I am working on a .40 cal STI pistol which is essentially a wide body 1911 which has a trigger problem. If the gun is cocked, and the trigger pressed, it requires a great deal of pressure to drop the hammer, way more than can be measured with trigger pull gauge. If you press hard and give up and then attempt to drop the hammer again, it requires very light pressure. This makes the pistol quite unsafe to use. Also, if you position your trigger finger at the top of the trigger so your finger is also rubbing on the bottom of the frame, the trigger pull is very light. If you bias your finger to the bottom of the trigger, it is very difficult to get the hammer to drop. Is this the result of a sloppy fit of the trigger in the frame? It's one of those triggers with the finger pad inserts that you can pop in and out and of course made for a wide body frame or double stack magazine. Thanks for any ideas on this!
