Fitch Williams
- Oct 31, 2004
- PA
I'm rebarreling a custom sporterized Springfield '03 that my father-in-law had built for my wife when she was in high school (1956 - 1960). It was test fired with military ammo that had corrosive primers in it, not cleaned, and the barrel was destroyed. I tried to shoot it, bullets went sideways through the paper at 50 yards. She brought it with her, along with 6 other rifles and a revolver, when we were married almost 43 years ago.
I decided to rebarrel it for her as a 43rd anniversary present. I'm almost there.
I recently posted pictures of cutting the extractor groove in the barrel breech for an '03 Springfield action, that was for this project. Today I got the stock modified so that tne new barrel fits. This is what it looks like so far:
The barrel needs a front sight ramp, front sight, final polish and bluing.
I did some measuring on the old front sight as installed on the old barrel. From the centerline of the old barrel to the top of the front sight bead is 1.022". The ramp height measured from the top of the barrel to the bottom of the dovetail is 0.380". The barrel OD at the front sight is 0.594". The front sight itself from bottom of dovetail to top of sight is 0.345"
The new barrel OD at the front sight location is 0.667". To get the same height, bore centerline to top of bead, I'd need a ramp with a height of 0.345". Brownell's sells one, Williams, that mounts iwth a scre that's 0.3445" top of barrel to bottom of dovetail. That will work if this is in fact the right way to determine the required height.
My questions:
Is the above a reasonable way to figure out front sight ramp height, top of barrel to bottom of dovetail?
If not, how do I go about figuring out what height front sight ramp I need?
Once the ramp is here, what is the best way to decide where it should be on the barrel so the rear peep sight zeros about centered?
This, like some other features of this project (square threads and cutting an extractor groove), is a first for me. Any suggestions are welcome.
Fitch
My questions:
Fitch
