Educator
- May 11, 2005
- NE Alabama
That was my first inclination...but I started thinking how it was going to hurt the slide in some way and then there is the added expense to have it coated.TIG to fill , and start over.
It's steelIt appears to be Aluminum ? if you have a skilled welder available that may be an option.
But, then strip the anodize, refinish the repaired area ,re-anodize.
Why dont you just replace the slide?
It's steel
This is probably my most logical and cost saving fix...I even thought about lowering the dovetail and adapt a sight to fit.Simply soft solder a close fitting steel plug in the lower cut and then recut the dovetail. The remains of the plug will only show at the end of the dovetail when the sight is in place. If the fit is close, very little of the soft solder will show. Cold blue the bare steel showing. Use soft-solder black if needed ( Brownells) on any solder showing. Done right, the repair will be hard to see.
RWO
It had to be operator error...It was a 2 flute taper mill and I must not have tightened it well. There is a whole list of things that keep running through my mind wondering what I failed to do.How the hell could that tiny end mill walk???? Was it even tight? In a mini mill? Amazing, I have been doing this for over 40 years, 1 or 2 end mills have walked and they were over 1" diameter.
That's a real good idea...I'll pick up a couple at least.Might be a good idea to get a solid holder or two for work like this. Something like a search for "solid R8 end mill holder" should show some options if you have the R8 style.
Notice
