Hi, all
I am looking at purchasing a metal lathe for general gunsmithing work. I have been told that I need a long distance between centres to hold a max length barrel, why?
In my experience as a hobby machinist and gunsmith the only possible advantage of a long distance between centres would be for barrel contouring or tapering. Generally you can get the desired contoured blank from the barrel maker.
Therefore the main operations I would want to perform on the lathe would be muzzle crowning, receiver thread cutting and chambering. All of these tasks can be performed on a relatively short bed lathe so long as the spindle bore inside diameter is wide enough to support the heaviest target barrel that one would want to fit ( with fixture mounted on spindle at back of headstock).
This is my preferred set up for barrel work as I believe it offers more rigidity than using steady rests. The other big advantage is that short bed lathes are cheaper than heavier lond bed lathes. My question is, have I considered all the facts here or is there another reason for wanting to fit a barrel or barrelled action between centres.
Cheers Gault
Cheers Gault
