Lead shot maker nozzles
Results 1 to 4 of 4
    Feb 2008
    Los Angeles Ca
    102
    Default Lead shot maker nozzles
    Can anyone here make me some nozzles for a lead shot maker like the james stewart shot drippers?
    Nov 2006
    CT-USA
    40
    Not the response you are looking for but do you have plans for a shotmaker? I have seen a sketch of a nozzle and will look for it.
    Feb 2008
    Los Angeles Ca
    102
    Default nozzles
    They are very simple but the holes are small. Normally they drill a small hole up to maybe 1/8" in the body of a SS bolt then perpendicular to that hold drill another hole around .024" in diam(.020 to .026" depending on shot size) from the side of the hex in to the larger hole. Saw some with some double holes that id love to have for larger production. Also the exit hole can be beveled at about 15 degrees but i dont think it mandatory.
    YouTube - the beter shotmaker #4
    YouTube - Changing drippers in the Littleton shotmaker
    Jul 2009
    Central PA
    18
    I would think that the easiest way to make them would be to find someone to EDM the holes in them. The number 9 drippers have a .020" hole, at least that's what mine measure out at. Also, Magma sells the drippers and are touted to be better. For as little as they sell for I'd be hard pressed to try and justify the work involved in producing a set. Here's my set up -
    http://www.youtube.com/watch?v=GeOgvvatkPM
    Tom
