Hello everyone. I am looking to build a bolt action rifle from scratch off of a custom built action I am designing based off of the Mosin Nagant action to allow me to use my Mosin Nagant parts. :P The rifle will be chambered in 7.62 NATO and will feature a Bartlien or Krieger barrel.
Not what I would choose... But not my project either! Moving on...
My question is what material should I make the action out of? I am planning on 4140 chrome moly.
Based on the specs. of 4140, the wide selection of conditions it is available in and the overall availability, 4140 is the only alloy steel I have ever used. That is
not to say there aren't other good choices... There are.
I am curious though, what kind of hardness should I be looking for?
High 20s to mid-30s Rockwell C works well. Much harder than that can lead to ductility issues. I used to use Rhc 35 for everything and have never had a problem. However, after some people suggested that there was a risk of galling using steel of the same hardness for the action and the bolt head I switched to using Rhc32 for the bolt head and Rhc35 for everything else.
Should I buy prehardened 4140 and do all machining from there?
I do. I find annealed 4140 to actually be more difficult to cut and provides a sub-standard finish. Further, I don't see the point of roughing the part, having the piece hardened and then setting up the part a second time to finish it. Setup is a BIG part of firearms work. Why do it twice unless there is a good reason?
I will be EDMing my bolt raceways and was thinking of buying non prehardened material, doing all rough machining and then getting it heat treated and then finalizing the job by EDMing the raceways and finish machining located from the EDMed raceways.
Although you can do it this way, see my comments above, I see no point to it. I have ZERO issues working pre-hardened (Rhc35) 4140. In fact I the Rhc35 for even the parts that don't "require" hardening. Bolt shrouds, trigger guards... They come off the machines with a better finish than if U had used annealed 4140. HSS tooling works very well with good coolant flow to the cutter. I use TiAlN coated carbide cutters and NO coolant for faster cutting on the mill. But I am also working with a CnC Bridgeport. On a manual machine, mill or lathe, HSS w/ coolant and slower feed rates would be a better combination.
I am looking for the highest possible accuracy while still remaining fairly affordable.
LoL! Building your own will cost you more than you think! And by orders of magnitude! There are lots of reasons to build your own bolt action. By the time you get done with the tooling, fixtures, jigs, and equipment you need to build a proper bolt action you could buy a very nice action pre-made by someone how is far better at it than you will be your first time out. I'm not trying to discourage you. I'm just trying to help you walk in to such a project with your eyes wide open.
Any ideas, suggestions or opinions? I appreciate it and am very excited for this build.
My "suggestions" ARE "opinions"... The same as anyone and everyone here. Use opinions at your own risk. Research EVERY THING for your self from as many different sources as you can. Thous who have done this more than once have found things that work for us. That does not mean that my way is the best way. I'm just in a place where I know
I can get the results I want repeatably. You will find what works best for you.
If you decide to move forward with 4140... McMaster-Carr has several flavors of 4140 ranging from annealed to Rhc35 and an ETD-150. Any of them could find it's way into a well executed design.
