Martini actions
Community On The Web
Results 1 to 8 of 8
Thread: Martini actions
    Jan 2003
    Elgin, IL, USA
    5
    Does anyone know of a source for martini actions or martini based greener shotguns? Also has does anyone have experiece rebarelling them. Caliber limitations etc. I plan on building one in a .444 marlin, 45/70 or mabey something bigger for the fun of it.
    Mar 2001
    alvaton,ky
    981
    7
    33
    the martinis imported in the 60's were plumb wore out & needed complete rebuilding.....a good trigger was a problem & scopr mt. had to be so high to give cartridge clearance , that it precluded decent stock fit ...i unloaded the pair i bought soon as i could ......the little rook rifle martinis were in better shape & made up into nice lite hornets & bees ....same probs w/ trigger /scope .....shud be better stuff out there to play with
    best wishes
    docn8as
    Jan 2002
    moscow, id, usa
    143
    I'd say doc is probably right, but if you are determined, I was told a couple of months ago that Sarco had a lot that had been converted to single shot 14 ga. guns and did not require a FFL to purchase through the mail. Mike
    GRUNING Guest
    FRANK DE HAAS(past away) HAS A NUMBER OF VERY GOOD BOOKS ON THE SUBJECT. THE BOOKS ,I THINK ARE OUT OF PRINT, BUT WELL WORTH THE SEARCH. AS FOR THE CALIBERS YOU CAN USE IN THEM, IT DEPENDS ON THE MODEL MARTINI. SOME RECEIVERS WERE STRONGER THAN OTHERS.
    MACHINING A BARREL FOR A MARTINI IS NOT THAT BAD,DOVETAILS FOR THE HANDGUARD AND SIGHTS. THE ONLY TRICKY THING IS MACHINING THE EXTRACTOR AND EXTRACTOR "SLOT" INTO THE BREECH FACE. IT'S NOT REALLY A SLOT. I WOULD RECOMMEND FINISH MACHINING THE EXTRACTOR WITH THE CHAMBERING REAMER
    HOPE THIS HELPS
    Dec 2002
    Flagstaff, Arizona USA
    64
    Home Gunsmithing Digest (1970) has a great article on making a Martini rifle in .444 marlin. He used a BSA action, numrich arms barrel and fajen wood. The rifle came out very nice. Load data also listed in the article. I can send you a copy of the article if you like.
    Larry
    Mar 2001
    Glendale, AZ USA
    428
    My buddy took one of the Indian shotguns with a 2 or 3 prong firing pin (I don't remember which) into a 45-70. It took a lot of work to get a working rifle. An extraction system, bushing the firing pin hole and designing a new firing pin, were the greatest trouble. I am not sure you want to convert one of the shotguns after watching him go through the trouble. Depends if it is a challange to get it done or a profit motivated job.
    At one time I think Navy arms had these actions but I don't even know if they are still in business.
    Jan 2003
    Elgin, IL, USA
    5
    Thanks for all the info. I have found a few sources for the 14ga and a few actions have come up on gunbroker.com. I have been told by others that the shotgun conversion can be a pain. I havn't seen one but I hear the firing pin setup is offset. Does any one know if I could replace it with a standard martini action parts? I have found a source in Canada for parts but no complete actions. Also any recomendations on manufacturer?
    Jan 2002
    moscow, id, usa
    143
    www.jouster.com has a Martini forum. It does not get much use, but you could ask and see what response you get. Mike
