You don't need a tenth indicator. Your compound is graduated in .001 increments, right? Then that is , at best , your resolution. Introducing a different resolution in a different direction will not improve that and will drive you crazy with the uncertainty that it will introduce.
Yes, measure the sine of the angle and the length. Then a calculator will tell you close enough. It isn't that critical anyway. Once the primer ignites they all conform to the chamber wall.
I'm using bushing type dies, resizing brass that was cream of wheat fireformed in a different barrel cut for that purpose only. The bushing type dies may not even be resizing the neck-shoulder junction.... This is exactly what I plan on investigating next after I verify the angle. Thanks.That could also be the wrong radius at the neck/shoulder. A chamber cast would allow side by side comparisom.
Honestly, I'm a bit confused: you went through the hassle of having a different barrel to fireform your brass. I would expect that the chambers in the two barrels to be cut with the same reamer without any re-sharpening in between. Otherwise, the whole setup doesn't make any sense to me.
Both barrels were cut with the same reamer, I'm just trying to verify that the reamer and resizing die match. There are other issues with the die that I didn't include because they weren't pertinent to my question on how to measure an angle.
Paolo
Thanks, I'll do some reading on that later, it sounds very similar to my issue. The die I have isn't a good match on body diameter to my chamber, so I mailed off some fired brass to Widden today so they can make me a non-bushing die. I'm guessing it fixes my issue.You are getting what called a doughnut from your bushing die, it's not an uncommon problem with some bushing dies. Read up on accurate shooter on how to fix it.
Notice
